Old 03-16-2008, 07:46 AM   #1
Tomikaze
Porschephile
Tomikaze's Avatar
987 cross drilled rotors on a 986??
Anyone know if this is an easy mod? I want an OEM cross drilled rotor without having to upgrade my calipers. In my research I'm pretty sure the base 987 uses the same calipers as a base 986. Would I be safe to assume then the cross drilled rotors from the 987 would be a direct swap? Thanks in advance. -Tom
2004 Porsche Boxster S
Portland, Maine
Tomikaze is offline   Reply With Quote
