Old 02-25-2008, 06:58 PM   #1
Lil bastard's Avatar
E1 is the Radio fuse (7.5A). D9 is the Amplifier fuse (15A), D8 is option code 680 upgraded Digital Sound Pkg. Radio and Sound system (7.5A) - if your car has this.
Also, disconnect the battery and reconnect.
Finally, pull the faceplate of the radio and clean the contacts on the radio and faceplate with a q-tip and alcohol - that's what it most likely is. The Faceplate communicates all the control functions (buttons) to the Head Unit electronically through the contacts on each. These get dirty, corrode, etc. Most of the issues with these radios are caused by these contacts being corroded, dirty, or out of alignment.
If you don't know how to pull the Faceplate, go here: http://www.beckerautosound.com/pdf_guides/om43-4462.pdf
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 03-29-2008, 03:12 PM   #2
If the fuses in the fuse panel are ok there is also a fuse in the back of the radio. If you slide the radio out and turn it around it is obvious where it is. It is only 7.5 or 10 amps depending on the radio. If the radio is not powering up at all this is probably your problem.
Techbones is offline   Reply With Quote
