Old 02-11-2008, 10:50 AM   #1
Solution!! Sprung Centered Clutch for a Boxster
as you may or may not know, replacing your flywheel with a solid lightweight option will cause chatter with a factory rigid clutch. generally, for a street car, a person with a solid LWF would want to use a sprung centered clutch disk to alleviate this problem.
in my search for a sprung clutch disk, i came to a realization: nobody makes one!with catman's help, i sent the Aasco flywheel dimensions to Spec Clutch and they will now provide sprung disks as a NO COST option to those of us who purchase their products. to order, first choose which clutch 'stage' you want from jdsperformance.com. then, call david at JD's performance to place your order & specify the sprung centered disk. your clutch will ship from Spec 2-3 days after you place the order (they have to make it). Voila; problem solved. BTW, spec said they may be working on a flywheel for us, too; i'll post more when i find out.
spec 'stages' (prices are for disk, pressure plate, release bearing & install tool):
stage 1: similar to OEM ($431)
stage 2: kevlar w/ hi-torque hub ($503)
stage 2+: dual friction w/ hi-torque hub ($575)
stage 3: 6-puck semi-metallic w/ hi-torque hub ($539, not very streetable)
stage 3+: full faced carbon metallic w/ hi-torque hub ($674)
stage 4 is a rigid racing clutch & stage 5 is a rigid drag clutch. also, you can specify a light weight option for another $80 (not sure how much weight this saves).
insite
'99 Boxster
3.4L Conversion
Old 02-11-2008, 10:52 AM   #2
They already should have the measurements, they made me one back in November. I dealt with Spec clutch directly.
Todd
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
tholyoak is offline   Reply With Quote
Old 02-11-2008, 11:03 AM   #3
Thanks for the info. I have been considering a lightweight flywheel for quite a while but didn't want the chatter.
2000 Black Boxster S
EVO Intake & GIAC Tuning
Headers & Porsche Sport Exhaust System
ROW M030 Suspension
Front & Rear Strut Braces
B&M Short Shift & EVO Billet Linkage
steve00s is offline   Reply With Quote
Old 02-11-2008, 11:48 AM   #4
edevlin's Avatar
Good info, my lightweight flywheel does rattle while in neutral with the clutch out. I only have 10-15K on my current clutch, so it looks like it will be with me for a while....
Ed
My Car Webpage
Old 02-12-2008, 05:47 PM   #5
Mine also chatters a bit (Aasco with Sachs sport clutch (non sprung). It'll be a while for me too.....
Patrick
Old 02-12-2008, 08:34 PM   #6
Where would one get a light flywheel? I have searched but found no supplier.
2002 S
Old 02-12-2008, 08:55 PM   #7
Todd
How do you like it?
Old 02-12-2008, 08:56 PM   #8
FYI for 3.2L owners,prices are anywhere from $130-190 more per kit compared the 2.5L.
http://www.jdsperformance.com/spec.asp?make=Porsche&model=Boxster&fcmd=cars
