Old 12-15-2007, 06:02 AM   #5
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by JFERR
If it's the battery, why is everything else working? Not enough power to turn the crank?
Exactly. I had the same problem. Lights on the dash all on, but engine wouldn't crank. Not enough juice. Get the battery replaced, and all will be well. You can go to an autozone, sears, or costco...they all have compatible batteries for the Boxster, or go to dealer for an OEM Moll replacement (for a higher price). Make sure you have your radio code, as that will need to be reset after the battery change.
