Old 07-10-2010, 04:57 AM   #41
To jtimmons
keep a positive outlook and ask the dealer to ask Porsche for some help.
Your service history and relationship with the dealer do matter in how they treat your request.
If you are the original buyer and bought it there even more.
Don't expect 100% but any help saves you considerable $ and beats the nothing you can legally deserve and will get from a negative/antagonistic approach.
Not implying you are.
Sure sorry to hear of your troubles.
Old 07-20-2010, 10:02 AM   #42
Hello, this is my first post to the forum, I'm going to be purchasing an early Boxster soon, I have my eye on one in paticular that's a 1999 with 50+++ miles on it. The carfax report shows that the front crankshaft seal was replaced 4 months after the car purchased new and the transmission was replaced at the same time with less then 6000 miles on it in August of '99.
At 16,000 miles in April 2000 the engine was removed, but does not say why. After that it has a pretty clean record other then failing smog at 44,000 miles, it has since passed smog several times including just a few months ago.
At what point did Porsche use the updated seals? Is the past service record any clue as to what I might be buying? Any way to check that I don't buy a hand grenade waiting to go?
This will be my 4th Porsche, I have had a 914, 944 & 911SC before, the 944 had a rod go with only 600 miles on the engine, of course Porsche replaced it, but it took 6 months to get the car back!
Thanks in advance.
Chase53 is offline   Reply With Quote
Old 07-20-2010, 10:10 AM   #43
Chase, are you sure you don't want to keep looking for another boxster that doesn't have so much drama and unknowns surrounding it?
Boxster are plentiful and cheap, and pristine models with a detailed service history can be found most everywhere.
BTW, you will quickly discover that in 1997, Porsche began making lots of crappy plastic parts on their cars that did not withstand heat or age well. Any 99 I might buy had better have quite a few things replaced on it recently for me to be interested enough to even test drive it.
Old 07-20-2010, 10:11 AM   #44
jcb986's Avatar
Thanks in advance.
The front seal could have been defected originally and needed a few miles for it to start leaking. Engine replacement is a good thing. The earlier models 97-99 had block casting problems, D chunk and RMS bearing failures. In 2000 they had made improvements in these areas.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
