Old 08-17-2004, 07:58 AM   #21
Send a message via AIM to Richard Truss
yes i think the esprit is in a different class than a boxster (well, the V8 twin turbo anyway). Im not a huge fan of the huggy-bear-diamond-pattern-seats, but overall a VERY nice car. i think we all thought you were talking about the elise -- which is not in the same class as the esprit (or boxster for that matter)
2000 S (3x Black)
Richard Truss is offline   Reply With Quote
Old 08-17-2004, 11:55 AM   #22
Lux
Originally posted by Automon
I am not looking at the Elise I am looking at the Esprit I have always loved this car and i want one period. Tell me that this car is not beautiful.
Thanks for the feedback
Automon
Automon, with all due respect, the Esprit was badass in the '80s and early '90s but are somewhat "disco" now. Their chassis dates back to, what, the '70s? Reliablility is horrible. And remember how they were in bed with Isuzu? Look at the steering wheel in that Esprit...it's an Isuzu steering wheel! Uggh. Well, I guess Porsche does have VW parts...but let's not go there.
Anyway, good luck with whatever you buy but keep in mind that you will most likely be trading a worry for a lot bigger worry.
Lux is offline   Reply With Quote
Old 08-18-2004, 06:17 AM   #23
Automon's Avatar
I just love the look of the car disco or not but my wife agrees with the rest of you she does not like it much at all. She keeps asking me what you guys think about the Lotus and it is funny because I tell her that all of you are on board with my decision.
Thanks again
Automon
Automon is offline   Reply With Quote
Old 12-23-2006, 12:57 AM   #24
2006 987
986_inquiry's Avatar
Originally Posted by mrmickeymouse
I do not like Lotus, but if I understand correctlly they have gone to the Toyota Celica GTS motor.
Reliabilty can't be that bad with that type of motor.
Now the rest I cannot speak for...
I don't know if anyone else responded to your statement but yes, the Elisa uses Toyota's 1.8 4-cylinder, exact same as the Celica GTS but with more tuning for slightly more hp & torque.
986_inquiry is offline   Reply With Quote
Old 12-23-2006, 01:02 AM   #25
2006 987
Couldn't agree more.
Old 12-23-2006, 12:56 PM   #26
talk about resurrecting an old thread! Geez, this one is over four years old!
Old 12-23-2006, 09:33 PM   #27
Hi,
No disrespect, but you haven't a clue what you're talking about. My 22 year old Turbo Esprit will run circles and blow the doors off 99% of all current models out there. The dated chassis you refer to will go 1.12G on a skidpad, something no stock Porsche will do.
In bed with Isuzu? Clearly you don't understand Lotus. Lotus is essentially two halves forming one company, the limited production manufacturing side and Lotus Engineering.
Lotus Engineering provides more than 50% of all revenues to the company by doing engineering work for many other car manufacturers. The Delorean, Toyota MR2, Vauxhall VX220, even the Aston Martin DB9 all had chassis work done by Lotus, so what if Isuzu also contracted with them? Lotus also developed the LT1 Engine for Chevy when GM owned Lotus ('86-'89) (though they don't brag about it - little wonder). And, let's not forget that the Lotus 910 engine (which powered the 1st 5 generations of the Esprit) also powered the Jensen-Healey before the Esprit was even released with little reliability issues. An Esprit is as reliable as you want to make it. It requires more frequent maintenance, but that's engineering, not reliability.
And, FYI, the stock Esprit Steering Wheel is a MOMO Wheel (and much nicer than any Porsche Wheel) with a proprietary Horn Button, not from some Isuzu parts bin! No Isuzu parts have ever been used in an Esprit or any other Lotus Car...
Happy Motoring!... Jim'99
Old 12-24-2006, 06:38 AM   #28
Brucelee's Avatar
Jim.
I think Lotus engineered the ZR-1 (LT-5) motor for Corvette, not the LT-1. That was the engine that was produced for GM by Mercury Marine and had 32 valves etc.
If this is correct, then Lotus SHOULD brag about that engine, as it was a terror. I had a red 1990 zr-1 and it was freaky fast for its day.
See below.
During 1986, General Motors acquired Group Lotus, the UK based engineering consulting and performance car manufacturing firm. The Corvette division approached Lotus with the idea of developing the world's fastest production car, to be based on the C4 generation Corvette. With input from GM, Lotus designed a new engine to fit in place of the L98 V8 that was powering the standard C4. The result was what GM dubbed the LT5, an aluminum-block V-8 with the same bore centers as the L98, but with four overhead camshafts, 32 valves. Lotus also designed a unique air management system for the engine to provide a wider power band by shutting off 8 of the 16 intake runners and fuel injectors when the engine was at part-throttle, while still giving the ZR-1 a stellar 375 hp when at wide open throttle.
In addition to the engine, Lotus helped GM design the ZR-1's upgraded braking and steering systems, and helped them pick the settings for the standard "ZX3" active suspension system that Chevrolet was fitting to the car, helping to ensure that the vehicle was more than just a modern-day muscle car with a big engine and no real capability on the track.
GM found that the engine required special assembly, and that neither the Corvette plant in Bowling Green Kentucky nor any of their normal production facilities could handle the workload, so Mercury Marine corporation of Oklahoma was contracted to assemble the engines and ship them to the Corvette factory in Bowling Green where the ZR-1s were being assembled.
The vehicle went on sale in 1990 and was available only as a coupe. It was distinguishable from other Corvette coupes by its wider tail section, 11" wide rear wheels and its new convex rear fascia with four square shaped taillights and a CHMSL (center high mounted stop lamp) attached to the top of the hatch glass instead of between the taillights.
The ZR-1 displayed stunning ability both in terms of acceleration and handling capabilities, but carried with it an astonishingly high price. MSRP for the ZR-1 in 1990 was $58,995, almost twice the cost of a non-ZR-1, and had ballooned to $66,278 by 1995; it has been rumored that some dealers successfully marked units as high as $100,000. Even at base MSRP, this meant that the ZR-1 was competing in the same price bracket as cars like Porsche's 964, making it a hard sell for GM dealers.
Rich Belloff
Old 12-24-2006, 07:00 AM   #29
Originally Posted by Brucelee
Jim.
I think Lotus engineered the ZR-1 (LT-5) motor for Corvette, not the LT-1...
Hi,
You're right! It was the ZR-1 Engine. What I meant about bragging was that Chevy, and the General, didn't go out of the way to tell the World that another Car Co. designed their best engine. Unlike Isuzu, Chevy didn't add any Lotus Badges to the car...
Old 12-24-2006, 09:47 AM   #30
Brucelee's Avatar
Smile
Originally Posted by MNBoxster
Hi,
That was just a great engine. The one I had was modded a bit and man, the acceleration was brutal.
These cars are now future collector cars IMHO and if I had the room and dough, I would start collecting while the prices are reasonable.
Rich Belloff
Old 12-24-2006, 07:02 PM   #31
MNboxster, do you have any insight on the Javan r1?
I am a HUGE lotus fan, and I am going to buy an elise in 07, but I just heard about this Javan R1 which is 500 lbs lighter than an elise, and uses a honda k20 engine (same one used in the s2k I believe) making 220hp.
It's only in England now, and is priced at the equivalent of $60,000 USD..
After hearing about this car, I am gonna have a tough time justifying the purchase of my lotus.
Any insight from you?
Miss my Boxster
Bavarian Motorist is offline   Reply With Quote
Old 12-24-2006, 08:55 PM   #32
Hi,
I can only tell you what I've been told by some friends across the pond and the press reports I've seen.
The main difference between the Elise and the Javan r1 is that the Javan is much more of a Kit Car. It has that Kit Car feel to it whereas the Elise feels like a manufactured car. Plus, the Javan r1, from what I know, is only available in RHD, which may make a difference to some.
One UK friend, who has driven it, compared it to the early TVRs in that it does go like stink, but doesn't inspire real confidence.
There are lots of these fringe cars out there, limited production cars which can be very satisfying, but which may be short-lived, especially when it comes to future parts availability.
And, personally, 60 large is too much to pay for a fun-only car of this ilk. Were it me, I'd take the $60k and plop it as a dwn. pymnt. on a Noble M400, or on a classic such as an Elite, early Jag, Healey, Porsche or Merc. - something which will appreciate in value, but hey, that's me...
Old 12-25-2006, 05:46 AM   #33
Oh yeah, I don't want a kit car either. I was under the impression it would be coming to the states.
If I was going for a kit car I'd just buy an ultima can-am and saved 30 grand
Thanks. I guess lotus is still at the top of my list.
Miss my Boxster
Old 12-25-2006, 06:30 AM   #34
Brucelee's Avatar
Speaking of kit cars, I keep my eyes peeled for the old kit car Ferrari Daytona that used to be on Miami Vice.
I passed on one several years ago and am still kicking myself for that.
Rich Belloff
Old 07-09-2010, 12:00 PM   #35
Thumbs down Engine Failure
I just received the dreaded call that my 2006 Boxster S has a catastrophic engine failure and will need to be replaced at a nominal fee of $15,000. We never missed a scheduled service and always took the car to the Porshe dealer for service. The car has 56,000 miles on it and is just out of warranty the service manager smugly told me. He said Porsche might help with the bill but after reading these posts I know that's not going to happen. The lesson I learned here is that although Porsche has a good brand name and you don't expect trouble get an extended warranty because these cars aren't all that. I was going to trade up next year but this has changed my mind and I no longer see Porsche the same way. There is something inherently wrong with this car engine and I am hopeful they figure out what it is. I expect to one day see a recall for this engine.
jtimmons is offline   Reply With Quote
Old 07-09-2010, 12:14 PM   #36
holy thread ressurection batman!
really sucks man sorry to hear... so what failed
Old 07-09-2010, 12:21 PM   #37
tnoice's Avatar
Have you had the Boxster since new? If you have, you might have a better chance of Porsche covering your new engine. I would also find a new dealership, because it sounds like they have a bad attitude already. Sorry to hear about your loss.
Lov'n my boxster!
2013 Lexus IS350awd
2007 Toyota FJ Cruiser
2004 Porsche Boxster S
tnoice is offline   Reply With Quote
Old 07-09-2010, 04:57 PM   #38
Engine Surgeon
Interesting that the '06 engine has failed.. We are just starting to see the "new" IMS bearings beginning to fail and it would be interesting to know if thats what your failure is.
BUT get a second opinion by someone that believes in repairing these engines. Lots of things that "down" an engine at the dealership are actually repairable with a little bit of innovation and elbow grease.. Problem is most dealershios just want to do oil changes and engine swaps.
BTW- With certain failures the frequency of service and how well an engine is cared for simply do not matter... Changing the oil in the engine doesn't ever impact the lubrication of the IMS bearing..
US Patent 8,992,089 &
US Patent 9,416,697
Old 07-10-2010, 03:25 AM   #39
That sucks man. Look at some other posts. People have been successful with getting Porsche to cover the engine costs.
Jake: I was wondering when you might start seeing 987 engines with failed IMS bearings. If I understand correctly, that one cannot be changed without a full teardown as the opening in the block is actually smaller than the bearing itself.
Chris
1999 986 2.5L, Stock Exhaust (S muffler), EVO Intake, 18" Stock rims (17" during winter), IMS Upgrade, 150k+ miles and counting!
87 944S brought back to life
Dragonwind is offline   Reply With Quote
Old 07-10-2010, 04:21 AM   #40
Engine Surgeon
We've already been seeing them, just not in higher numbers. As these cars come out of warranty over the next few months I know we'll see an increase.
The bad part of it with the '06 and newer engines is the fact that the bearing is larger than the access port in the crankcase. What that means is an absolute impossibility of bearing retrofit as the old bearing cannot be removed.
When one of these bearings starts to go bad, the engine is 100% compromised. Wonderful execution by the engineers, wonderful.
US Patent 9,416,697
