Old 10-19-2007, 01:54 PM   #10
The Imagine site has numbers problems.
First, 80hp gain over 150hp base is not 38%, it's 53%.
Second, if they are using about 5 psi, there is no way they can approach even 38%. The theoretical max in ideal conditions is 6.8% increase per 1 psi; 5 psi would therefore be a 34% increase, max, assuming all other factors perform at their theoretical performance limits. Operating over 5psi is an iffy proposition without an intercooler, so they can't be getting 38%, let alone 53%.
Lastly, it's not all about peak power; it's where in the rpm range the power happens. If you were to overlay the two dyno curves of the Imagine blower and the twin turbo, I bet the turbo curve is a lot higher than the blower curve at lower rpms. Even if the blower were to provide more peak power, it's going to do it at much higher rpms; the turbo car would be far in front of the blown car by that point.
A supercharger can't build boost until the revs are up, unlike a propertly tuned turbo setup. What you want is performance at lower rpms, unless you are at the track and never let things get below 5000...
Originally Posted by NickCats
Gary,
Just wondering, how is it that the Turbo provides more power than the Supercharger ?
Imagine Auto's website claims approx. 80 additional hp :
http://www.imagineauto.com/boxster%20sc.htm
While TurboWerks claims an additional 65 hp :
http://www.turbowerx.com/Products/BoxsterTurbo/BoxsterTurbo.html
Thanks !
Nick
monza is offline   Reply With Quote
