Old 08-01-2004, 04:25 PM   #1
oil change
Hello, I am new here. We just bought a 2000 porsche boxster and are very excited to have it. We are wondering how the oil is changed, if it has to be done at a dealership and about how much does it usually run?
any information would be great.
thank you
vision is offline   Reply With Quote
Old 08-01-2004, 06:41 PM   #2
Yes the oil can be changed by youself or you can have the dealer do it for around150- 200 bucks. Many boxster owners do it themselves because it is an easy task to do. There is alot of info on this forum about that topic. Click on search and type in "change engine oil" or something to that tune and there should be a good deal of info that pops up. If have any difficulties finding what you need let us know.
Old 08-02-2004, 12:27 AM   #3
Thank you for your reply. I have tried the search option with several different variations of changing oil but keep coming up with something to the effect of "must be at leat 4 words" could not get a singel topic to come up. any suggestions?
Old 08-02-2004, 11:19 AM   #4
This one of many out there:
http://www.renntech.org/forums/index.php?act=Content&code=diy_oc
mrmickeymouse is offline   Reply With Quote
Old 08-02-2004, 04:41 PM   #5
That took me to a different forum? is there no informtion on oil changes on this site?
Old 08-04-2004, 01:06 PM   #6
donv's Avatar
Yes, the search function requires at least 4 characters, but you can make some of them wildcards (like '*') to get around it... so to find anything that contains oil, you can search on oil*, which gets you these results:
http://www.986forum.com/forums/search.php?action=showresults&searchid=19987&sortby=lastpost&sortorder=descending
donv is offline   Reply With Quote
Old 08-04-2004, 03:54 PM   #7
Thank you that helped a lot. appreciate it.
Old 08-05-2004, 09:00 AM   #8
http://www.986faq.com/7-0/oil.asp
http://www.realtime.net/~rentner/index.html
lsc7354 is offline   Reply With Quote
Old 08-07-2004, 05:57 PM   #9
b0xt0La
Alienz's Avatar
I just changed the oil two days ago, it was so easy. You need a tool to remove the oil filter housing, you can use the porsche tool or a third party one. I used a tool (I don't know what it's called )which looks like a cylinder with a handle attached to it. I fit it around the housing, tightened it then unscrewed. Maybe tool pants knows the tool I'm talking about.
Alienz is offline   Reply With Quote
Old 08-09-2004, 04:20 PM   #10
can you post a pic of it for me? thanks
Old 08-10-2004, 08:51 AM   #11
Old 08-10-2004, 07:49 PM   #12
Send a message via AIM to Richard Truss
is that the filter wrench that i need to get for this? or will the old flip=floppy filter wrench to the trick as well?
2000 S (3x Black)
Richard Truss is offline   Reply With Quote
Old 08-11-2004, 01:01 PM   #13
If you have a strap type filter wrench that is the right diameter it will work.
Old 08-11-2004, 01:16 PM   #14
