Old 08-05-2007, 01:34 PM   #1
Best Brakes for DE
I am new to Porsche and am lookng forward to my first DE next month and another one in October. What are the best brakes to use that will do well for DE and everyday driving in between for my 2000 Boxster?
popey986 is offline   Reply With Quote
Old 08-05-2007, 02:53 PM   #2
Pat
Check out Pagid Sport Blues with fresh fluid.
"Of all the extreme sports I've ever participated in- windsurfing, kite boarding, wake boarding, tow-in surfing and snowboarding- skiing, for me, made everything else easy."
-Chuck Patterson
Pat is offline   Reply With Quote
Old 08-05-2007, 09:05 PM   #3
Track rat
Topless's Avatar
Stock pads with plenty of meat left... no problem.
Old 08-05-2007, 09:07 PM   #4
Absolutely flush out your brake fluid, great advice there. I use ATE and switch back and forth from the gold to the blue.
After my first DE my brake pads squeeled for a week. Seems that they glazed over. So I switched to cross dilled and slotted Zimmermans which solved that problem. This year I switched to Pagid orange and they are incredible. They squeal like crazy on the street though so you will want to change them out after each DE.
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
der Geist is offline   Reply With Quote
Old 08-06-2007, 03:04 AM   #5
Make sure you get OEM pads. Due to a mix up at my suppliers I had to run some cheap generic pads and they were useless, overheating after only a few sessions. Even worse the amount of dust created was crazy and I am still struggling to clean off the wheels, luckily they are a spare set . My OEM ones used for the previous events did not have the same problems.
After speaking to a couple of the other drivers at my last event I am waiting for a set of EBC Yellow to be delivered, they rated them highly and their wheels were spotless afterwards.
Have fun!
noone986s is offline   Reply With Quote
Old 08-06-2007, 07:02 AM   #6
if you plan on doing frequent DE's, invest in a set of good race pads (Pagid Orange, Hawk HT-10). they work MUCH better on the track and will last a lot longer. swap your street pads back in when you're done.
if you're just doing one DE, stock pads should be fine
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
