Old 07-10-2007, 12:33 PM   #1
Thanks guys, I will track down a set of OEM wheels.
HK987, you really need to get your car on a track to see what they are capable of. Eye opening
noone986s is offline   Reply With Quote
Old 07-11-2007, 02:46 PM   #2
Make sure you check that the tires you're going to put on the wheels will be a good fit. I thought that for most 17" 225's (at least R compounds) you had to use a larger wheel width than 7"?
BTW - I run 17x8.5's (OEM's without any spacers) all the way around with Victoracers (225 front/255 rear) and haven't had any problems, but I only do autocrosses. It currently handles very neutral but I'm considering going to 245's up front next time I need tires. At the same time, you're not going to fry your PS pump doing autocrosses...
Sammy is offline   Reply With Quote
Old 07-12-2007, 02:51 PM   #3
Thanks Sammy. I managed to get a set of OEM 17's from Ebay here in the UK, they have some Kumho tyres already fitted that I will use up over the next 1 or 2 events then look at some semi slick tyres. Probably the Yokohama AO48R or Toyo 888R
Cheers
Old 07-13-2007, 07:27 AM   #4
Track rat
Topless's Avatar
This is true. Surely you won't damage your PS pump during a 1 minute Auto-X run.
Those problems all occurred on cars during extended 20-30 minute track sessions with oversize front tires. If you do track your car and run big rubber up front check out what others are doing: Beefing up front end steering components and a PS pump cooling system. Then you can run your car all day without worries.
