Old 07-04-2007, 11:28 PM   #1
sticking gear lever release and brake lights problem
HI All
Boxter electrical fault. Can anyone advise how to solve this?
I cant get my gear lever out of park by pushing the release button ( unless I trick it by holding it down before starting the car - which works). Its probably a sticking switch or something similar ?Also my brake lights arent working sometimes - connected problem?
Any advice appreciated - thanks
barrylsack@hotmail.com
barrylsack is offline   Reply With Quote
Old 07-05-2007, 12:49 AM   #2
If your brake lights are working intermittently, you might want to check out your brake light switch... These are known to go out.... I had the same problem a little while back, replaced the brake light switch (easy 10 minute job), and they work perfectly now.
Hope this helps...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 07-05-2007, 02:31 AM   #3
.....and since you have to apply the brake to shift fror Park, I'm betting your two problems are common to one part.
http://i19.photobucket.com/albums/b1...dingAvatar.jpg
Sold September 4th, 2007.
Rodger is offline   Reply With Quote
