If your brake lights are working intermittently, you might want to check out your brake light switch... These are known to go out.... I had the same problem a little while back, replaced the brake light switch (easy 10 minute job), and they work perfectly now.
Hope this helps...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
