Old 06-13-2007, 12:00 PM   #1
Send a message via MSN to CJ_Boxster
Exclamation Rotor Whoa's... Need some advice
Ok, In late Feb I purchased a Front & Rear set of Zimmerman Cross-Drilled & Slotted rotors from ebay. About 3 weeks ago I noticed a tad bit of wobble under braking and 1 week ago it had gotten alot worse and more obvious that the rotors were the cause of the wobble.
Now they wobble like a mofo when braking at speeds higher than 60mph. Emailed the Seller and told him if they can replace them, since i see a similar auction on ebay for the same rotors but with a 6 month warranty.
They replied with "rotors come with 30 day warranty". So that avenue is no good for me. Rather than Replace the rotors all over again, Is there anyway I can have them cut/straightened?
I heard that not all Rotor cutting machines can do Cross-Drilled/Slotted rotors but some can... Is this true? if so, where might I find a shop with this type of machine in the Los Angeles area?
Any advise or ideas welcome.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
