Old 06-13-2007, 01:41 PM   #7
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by Pat
You said, "....obvious that the rotors were the cause of the wobble." Although it may happen under braking, the rotors may be in good shape. There's a decent chance their are pad deposits on the rotors, causing unequal friction as the disc rotates along the pad. Try re-bedding the pads an see if that cleans it up. To do this, threshold brake 5-7 times from 80 mph to 20 mph or so. This will heat up the rotors and clean off any potential deposits. Your brakes may smoke after this, but don't worry about it if they do. Try driving without using the brakes at all for about five minutes after doing this to allow the brakes to cool evenly.
Also, what kind of pads are you using?
Be sure not to use the parking brake when the rotors are very hot.
Disclaimer: I'm new to the Boxster scene, so my comments are based on Audi experience, which is significant.
Im using the OEM porsche pads, Ill give that a try if there isnt much traffic on the freeway but I dont think I could safely get that done in city fwy's.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
