Old 06-12-2007, 10:19 AM   #1
Send a message via MSN to CJ_Boxster
How slowly should a good OEM strut compress?
I have a question. Say i have a strut already out of a non-S boxster and im not sure how old they are, If they are in good working condition, Should they be firm and slow moving when i try to press the rod back into the strut? Assuming there is no spring on it anymore of course...
How many seconds should it take for the rod to bottom out if I leaned on it with all my weight (About 200lbs)?
Also, how quick should the Rod retract back out the strut?
Reason I am asking is because I will be replacing my old struts soon and I havent a clue weather not they've been replaced and when I remove them, i want to try an inspect the bound and rebound of the shock so I judge weather they still had life in them or if they are totally worn out. Any help would be greatly appreciated.
Thanks in Advance.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
