Old 11-22-2013, 02:19 PM   #1
Question 03 boxster computer problems
How many computers under driver seat in a porsche 03 boxster S. My cluster lights are always on and draining my battery and the gauges not working, also the top is not opening, looks like the switch is not working, neither the heating or air conditioner. I have two computers under the driver seat, one looks like somebody was working on(I bought the car knowing that was a electrical problem, with dash not working), could somebody tell me the name of those computers or the numbers, please? any help will be appreciated.
carlosnolasco is offline   Reply With Quote
Old 11-22-2013, 04:51 PM   #2
jsceash's Avatar
There should only be one under the drivers seat it is the immobiliser 99661826203 for a 2003 2004
Old 11-24-2013, 07:57 PM   #3
Hi, Thanks for the replay
It is another one, I think that is for the heating seat and another things. It has a lot of connectors. My problem is the top is not working, the passenger window, heating and the dash in on all the time, so is draining the battery. I know how the immobilizer, but this one is larger and has more connectors than the immobilizer. It looks like an Italian bread, like a flute. Maybe I need to take a picture and post it.
Old 11-25-2013, 09:11 AM   #4
jsceash's Avatar
Sound like some one did something non-spec. There is a relay attached to the seat bottom for the heated seats about 1-1/2" square by 2" on my 2003 and the immobilser, which is attached to the floor panel nothing else under drivers seat. A picture may help, unless it is someones attempt to bypass the immobiliser.
Old 11-25-2013, 02:47 PM   #5
I will take a picture and will post it, after I get home. I disconnected the box from all the plugs and the dash stayed on, heat, top, and passenger window not working. Thanks
Old 11-27-2013, 10:16 AM   #6
I took these pictures to see if somebody can help me to identify this part. Is connected under the driver`s seat. I have a electrical problem, dash always on, not heat or air conditioner, the top is not working, could be this part the problem? the number on the part is: 996 618 587 03
Old 11-27-2013, 10:43 AM   #7
BYprodriver's Avatar
Lear makes the seats, so I'm sure it is seat related. I'm guessing the immobilizer was wet at one time which started the electrical problems, & is the reason the car was sold.
Old 11-27-2013, 01:19 PM   #8
Thanks Byprovider
The engine and transmission are working without any problem. So if the immobilizer get wet, the car does not turn, am I right or could be bad and still the car can run? I am driving the car and has not issue besides the electrical problem with the top and some components in the dash, like the heat and air conditioner. Also the seat belt stuck and I can not pull it out. So the part that I show in the pictures has nothing to do with my problems? I found the part in PET diagram and it said that is the control unit. Thanks in advance for your help
Old 11-27-2013, 02:26 PM   #9
Originally Posted by carlosnolasco View Post
Thanks Byprovider
I could be wrong, I thought your engine was bad also. Ignition switches are known to go bad & cause multiple electric problems.
Old 11-27-2013, 06:11 PM   #10
jsceash's Avatar
The unit in the picture is the seat memory control unit. The seat had memory for several different drivers and by selecting the saved setting the seat would position itself for that person. There should be 4 buttons on the door sill between the front and rear trunk open switches.
HTML code is Off
