Old 10-05-2024, 05:30 AM   #1
Wiring offroad spot and flood lights
Hello!
I’d like to install spot and flood lights to the top of a recently purchased roof rack on my 2001 986.
I’d like to control them with a switch replacing one of the blank ones in the center console.
How can i go about wiring this?
Thanks!
Last edited by Pathologicaldriver; 10-05-2024 at 05:51 AM. Reason: Incomplete post
Pathologicaldriver is offline   Reply With Quote
Old 10-05-2024, 06:10 AM   #2
Motorist & Coffee Drinker
78F350's Avatar
Did your lights come with a wiring kit? I have found that the kits that come with a switch and relay are the best way to go.
Otherwise, the simplest way is to run a wire from the 'phone option connector' under the center console for +12v to your switch, then on to the lights. See: What does this plug under the dash go to?
Old 10-05-2024, 06:23 AM   #3
Thank you! That phone connector is really cool.
I’m still researching which lights to get, based on if I can use a center console switch, included basic toggle switch, or some bluetooth panel.
I’m also new to car wiring.
Old 10-05-2024, 06:28 AM   #4
Thank you!
That phone connector seems perfect.
I’m still researching which lights to get, depending on if i can use a center console switch, kit toggle switch, or a bluetooth panel.
