Old 10-05-2024, 06:23 AM   #3
Pathologicaldriver
Thank you! That phone connector is really cool.
I’m still researching which lights to get, based on if I can use a center console switch, included basic toggle switch, or some bluetooth panel.
I’m also new to car wiring.
Did your lights come with a wiring kit? I have found that the kits that come with a switch and relay are the best way to go.
Otherwise, the simplest way is to run a wire from the 'phone option connector' under the center console for +12v to your switch, then on to the lights. See: What does this plug under the dash go to?
Pathologicaldriver is offline   Reply With Quote
