Old 12-15-2020, 05:31 AM   #1
flouese's Avatar
Relocating hvac
Before you ask, I've searched the forum for a DIY on moving the HVAC from the bottom to the top. I have a source for the trim piece, just need to know how to move it.
Please advise. Thanks in advance.
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 12-15-2020, 11:29 AM   #2
1998 Boxster Silver/Red
Here's a few I found:
relocating the climate control
986 Boxster - swap radio & climate positions
https://rennlist.com/forums/boxster-and-boxster-s-986-forum/980866-relocating-ac-controls-to-the-cd-changer-spot-and-cable-extensions.html
1998 Porsche Boxster
Old 12-15-2020, 11:32 AM   #3
jaykay's Avatar
I have a post on this.....and carried it out. Try searching under my user ID.
If you don't find it let me know.
The job was very difficult in my car. I had to start a Yoga practice in order to assume the postures required to pull the harness down to the right spots. It's easier if you are not doing the radio. I also split loomed every thing I could in order not to damage wiring
There are other members who have done it as well and they are likely more skill at wiring
986 00S
Old 12-15-2020, 05:32 PM   #4
flouese's Avatar
I've seen those. None of them tell you how or what to move.
99 Boxster base
1966 912 3 gauge
Old 12-15-2020, 05:52 PM   #5
jaykay's Avatar
Whatever you disconnect up top you need to pull down south to where you place your hvac panel. Right side and down worked best on my car.
Search for this:
Hvac and radio relocation - harness route
986 00S
