Old 09-29-2019, 06:37 AM   #1
M9G
2002 2.7 Boxster in green
M9G's Avatar
my new head unit
Installed my Double Din Android 9 multimedia head unit this weekend
Built in satnav
Plays all multimedia
Connects to phone
Wifi
2 USB ports installed
I took pics throughout the install and will post up a tutorial when i have a couple of hours
M9G is offline   Reply With Quote
Old 09-29-2019, 06:55 AM   #2
Who's askin'?
maytag's Avatar
Looks very, VERY nicely done. Looking forward to the tutorial. Mostly because I'd like to understand the trim-out of that lower console. I tried to swap my a/c controls to that location but the trim piece is a different shape altogether.
Old 09-29-2019, 01:36 PM   #3
01 Basalt Metallic 986
JimmyBad's Avatar
I have a similar trim piece that I got in my kit that I did not use.
Lower console cubby for HVAC controls
JimmyBad is offline   Reply With Quote
Old 09-29-2019, 02:32 PM   #4
Who's askin'?
maytag's Avatar
PM sent
Old 10-06-2019, 04:58 AM   #5
Looks great..........what head unit/trim piece did you use?
John
John Thomson is offline   Reply With Quote
Old 10-06-2019, 05:24 AM   #6
M9G
M9G's Avatar
John
The head unit is by Xtrons, this is the third car ive fitted an Xtrons unit in and they are really good. This one is the TA7091PL - https://xtrons.co.uk/double-din-android-9-0-ta709ipl - look on ebay as the same unit is cheaper and its from Xtrons using a different ebay seller name.
The cage is from a company called Connects2 who I use for all my cages and harnesses for double din head units. They have a great back up customer services aswell.
The ebay seller for this cage is Dynamic Sound who is the official distributor for Connects2 - https://www.ebay.co.uk/itm/Car-Stereo-Radio-Double-Din-Fitting-Kit-Fascia-Panel-Adaptor-Black-for-Porsche/352465150023?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Also the harness came from the same company and the only wire I had to install was for the illumination of the head unit which I took from the feed for the bulb on the cigarette lighter. This harness is for a boxster with built in amp but NOT fibre optics - https://www.ebay.co.uk/itm/CT53-PO01-CD-Wiring-Loom-Harness-Active-System-Adaptor-For-Porsche-911-Boxster/401631954462?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 .
They also do the harness if yours does have the fibre optics
It was all really easy to install and only took a couple of hours. I do have a reversing camera to fit which I will do one day
Regards
Old 10-06-2019, 06:06 AM   #7
I have this fitted to mine but fancy the added functionality an Android unit.
Chinese Double Din Fitted
Did the surround come with it?
john
Old 10-06-2019, 06:18 AM   #8
M9G
M9G's Avatar
john
Click on the link for the cage, that's the surround for the head unit and the other surround for moving the climate controls
Old 10-06-2019, 06:22 AM   #9
M9G
M9G's Avatar
Just looked at yours and you have the same facia as me, its the head unit thats wrong. They do state on the eBay listing for the facia that some Chinese head units are too big, which is the problem you had. The Xtrons unit fitted perfectly
Old 10-06-2019, 06:58 AM   #10
Many thanks.
I fitted that a few years back and at that time could not get the correct facia so cut that oneto fit.
Your looks much neater.
John
Old 10-07-2019, 03:58 PM   #11
A 986 S's Avatar
Me too!
It looks like you have the current version of the same head unit I installed a couple of years ago. One of the best things about this one is that it doesn't have a brand logo on it's face so it's not quite so obvious that it's an aftermarket unit and it's also easy to change the home screen to something that looks like it could be OEM.
You'll really like the GPS speed function on the Torque app as it is far more accurate than the car's speedometer.
You can see more of my install here : https://rx19jones.wixsite.com/projectboxster/projectboxster-3
Cheers - dj
2002 Boxster S Orient Red Metallic / Graphite Gray
https://rx19jones.wixsite.com/a-986-s
A 986 S is offline   Reply With Quote
Old 10-08-2019, 12:44 PM   #12
M9G
M9G's Avatar
Cheers - dj
nice install :-) They are great well made units, this is my third. My startup logo is the Porsche logo :-)
Old 07-14-2020, 05:16 PM   #13
I know this post is more than several months old, but was wondering if you know if they offer a head unit with a dial for volume. It's the one thing I don't like about most double din after market screens is the buttons for volume. Also, for they have an Android Auto version or just head units that run on Android OS? Install looks great btw.
Goldenzrule is offline   Reply With Quote
Old 07-14-2020, 09:53 PM   #14
M9G
M9G's Avatar
Thankyou
Go on the xtrons website and have a look to see if they have what you are after
Cheers :-)
