Old 12-10-2017, 10:06 AM   #1
Decals
Looking for recommendations on cold weather (Minnesota) installation of decals
Donald29 is offline   Reply With Quote
Old 12-10-2017, 12:18 PM   #2
Do it indoors.
deathsled986 is offline   Reply With Quote
Old 12-10-2017, 02:25 PM   #3
Originally Posted by deathsled986 View Post
Do it indoors.
Reply of the year right there
Old 12-10-2017, 07:36 PM   #4
Thanks for the response. Not what I was looking for. What I had in mind was a minimum temperature that would work for a proper installation. The Boxster is in my garage which can be warmed up.
Old 12-11-2017, 01:21 AM   #5
still plays with cars...
BoxsterSteve's Avatar
I’d say 50-55F... more so that you’re not freezing your giblets off.
Six speed 2000 Boxster S
Old 12-11-2017, 04:41 AM   #6
most decals are plastic, so the hotter it is the better adhesion you'll get.
Old 12-11-2017, 06:10 AM   #7
You can also use a heat gun to warm the area up
Woody
Old 12-11-2017, 06:49 AM   #8
jsceash's Avatar
Start with the decal at room temp. Heat gun the surface your applying it to. I would do it inside if possible. If it warmer than 50 inside you got it licked.
Old 12-11-2017, 11:16 AM   #9
Hey guys (Boxsterssteve/Randallneighbor/jsceash/itsnotanota):
Thank you for the information. much more useful.....Steve, 50 above would require shedding some outer garments!
