Old 03-27-2017, 03:33 PM   #1
Beginner
Jamesp's Avatar
Will it work?
Will I end up with a new headlight seal, or the headlight irretrievably glued into the fender?
I've been working on headlights and of course the seals have turned into something resembling decomposing tar, but without decomposing tar's redeeming qualities.
So I've been thinking on making my own, not necessarily identical to stock, but at least a seal, and using better material would be nice. This is my first attempt.
Enter my painting and home repair skills. Surely Home Depot has something that would work as a seal, they have everything else.
and here it is...
Sun resistant RTV oh yeah, if I can form a seal out of that then I'm good for 30 years if the GE marketing team is telling the truth. But where to get the other half of the mold?
With a little high tech silicone release agent on the blue tape...
I should be good to inject some silicone
and voila
So it is currently curing in the garage as I type.
Did I just glue my headlight into the fender, or find a way to make a new gasket?
2003 S manual
Old 03-27-2017, 03:39 PM   #2
still plays with cars...
BoxsterSteve's Avatar
If it works out, could I send you a couple of rolls of painter's tape and you can fashion me a set?
Neat idea, I hope it works out for you.
Six speed 2000 Boxster S
Old 03-27-2017, 04:05 PM   #3
oldskool73's Avatar
I bought a set of used headlights, and the previous owners had used a strip of rubber seal with a right angle bend and just glued them on and cut to length. They fitted and worked well, I didn't even notice they weren't original until I came to remove them to open the lights. Sure you could get something similar from a homeware store.
oldskool73 is offline   Reply With Quote
Old 03-28-2017, 10:55 AM   #4
Check out Steele Rubber...I am fairly certain you can find a suitable replacement...
Steele Rubber Products - Universal Parts
anotherturbo is offline   Reply With Quote
Old 03-31-2017, 06:47 PM   #5
Beginner
Jamesp's Avatar
No it won't work.
2003 S manual
Old 04-01-2017, 02:59 AM   #6
itskenallen's Avatar
I don't think this will work very well. The silicone will fall apart first time u go to change a bulb.
Sent from my SM-G928F using Tapatalk
itskenallen is offline   Reply With Quote
Old 04-01-2017, 04:51 AM   #7
Spinnaker's Avatar
headlight trim for boxster 1998
Old 04-01-2017, 04:58 AM   #8
steved0x's Avatar
Originally Posted by Jamesp View Post
No it won't work.
You gave it a good try, any pictures or did it just fall apart when you took the tape off.
Old 04-01-2017, 06:20 AM   #9
You have my respect for trying I took the seal completely off my headlights.
Woody
Old 04-01-2017, 07:12 AM   #10
Beginner
Jamesp's Avatar
There were a couple of problems. The silicone stuck to the tape despite the "silicone release agent" I used. It would tear before releasing from the tape. I think I could overcome that, but the real problem was the final finish of the silicone would be uneven and stick out like a sore thumb. It's OK to have that unevenness in a bathtub install, but sitting between the smooth shiny fender and light it was clear it would be very noticeable.
2003 S manual
Old 04-01-2017, 08:22 AM   #11
Like I've advised before, find a used set with good seals (or buy a brand new set of headlight for $800 ) and use those. Then sell the headlights you just bought. Just make sure sure that you note in the sale that the headlights have no seals. Sometimes, you can break even. At the most, you might be out $100 for your new seals.
It's risky, requires an initial investment and is time consuming.
Foam rubber insulation weather stripping from Home Depot is better than nothing.
