Old 03-06-2017, 03:41 AM   #1
1998 Boxster
Green bolts
I occasionally notice bolts that are tinted green. Does anyone know the significance of the green tint?
rah rah 986 is offline   Reply With Quote
Old 03-06-2017, 05:46 AM   #2
steved0x's Avatar
On airplanes I have seen metal that is corrosion protected with zinc chromate which leaves a green tint, but I haven't noticed any green tinted bolts on the Boxster (but then I am red/green colorblind so I may not notice them). Maybe someone did a repair and used some sort of zinc coated bolts that developed a green tint?
Old 03-06-2017, 05:49 AM   #3
On the slippery slope
JayG's Avatar
Are you referring to some green on bolt threads ?
If so, that is likely thread locker.
2004 996 Targa Tip
Instructor - San Diego region
Old 03-06-2017, 08:24 AM   #4
07 Carrera S Cab
Boxtaboy's Avatar
There are green tinted bolts on the Boxster. Here's an example of 2 green tinted bolts used to secure the latch on the underside of my car's rear trunk. I'm guessing that's just some sort of anti rust solution that the bolts are dipped in.
Old 03-07-2017, 03:41 AM   #5
Multi-Boxer Driver
Deserion's Avatar
Most of the green bolts I've seen are on suspension components. I've seen plenty on Volkswagens, just an anti-corrosion coating.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 03-07-2017, 08:31 PM   #6
I understand these Porsche fasteners use a dip-spun applied zinc-aluminum coating called Dacromet, but the current name for the more environmentally-friendly version of it is called Geomet. The dacromet/geomet coating alone looks kind of matte silvery in appearance, (like aluminum) and you will see this below the green coating, if you ever have "cleaned" grease or oils off your fasteners with an aggressive solvent cleaner, (like brake parts cleaner - or anything with acetone on it, will remove that green coating very quickly.) Solvents will not touch the base Dacromet (aluminum/zinc), however.
Based on the following reference, which says [Porsche-spec'ed geomet] "sealers include ... pigmented ... green for identification purposes", we might infer this solvent-removable green topcoating to be an "Inorganic silicate sealer topcoat", which "provide[s] consistent torque tension values and additional corrosion protection."
http://michiganmetalcoatings.com/yahoo_site_admin/assets/docs/Geomet_Brochure.28482815.pdf
In my experience, it's still a good idea to clean older dacromet fasteners before re-using, and also apply anti-seize, ideally. The commonly available, gray (I think zinc-based) anti-seize seems to play very well with the dacromet fasteners when applied thinly and evenly on the threads, and doing this will also help keep water from corroding aluminum whenever these fasteners are ever threaded directly into aluminum.
2001 Boxster
Old 03-15-2017, 08:36 PM   #7
lkchris's Avatar
I agree with corrosion protection responses, but note my BMW motorcycle has lots of fastener heads with a dab of green paint--factory quality control, tightness verified.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
