Old 04-02-2016, 11:03 AM   #1
Ben-Auto-Design
Ben006's Avatar
Pedal extension!
Hello guys!
After more than a year behind the wheel of a 986... I still struggle sometime with rev-matching downshifts...
I looked at pedal extensions, and, well, Porsche prices :/
So, I made mine:
It's just a plastic prototype, and I used the screws I had laying around... And I had to cut a piece off it... so it looks terrible from behind!
I haven't tested yet (I did a test with piece of wood taped to the pedal... and it worked great).
I'll work on it a little to make it easier to install, with the right screws...
This one is made the same way I made the plenum, but can be made out of stainless steel and steel for not much (around 30$) while a plastic one should be around 10.
Tell me what you think! (except if you say that the fixation I used looks ghetto, I already know ^^)
Ben.
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
Old 04-03-2016, 08:00 PM   #2
Hey, whatever gets the job done!
I have the Rennline set but your solution looks pretty good. Well done.
Old 04-03-2016, 08:07 PM   #3
Can you do it in aluminum?
Old 04-04-2016, 01:35 PM   #4
Ben-Auto-Design
Ben006's Avatar
Thank you
I wasn't able to test it fully on my daily commute, but should be good!
It is possible to do in aluminum, but it's too exepensive to justify it.
I really think the nylon one is strong enough!
I'll make it available at the end of the week, just to make sure there's no problem that I haven't seen yet
Ben.
1982 928 S Euro
Old 04-07-2016, 01:02 PM   #5
Ben-Auto-Design
Ben006's Avatar
Hi!
After a few days of use... it seems that the problem doesn't come from the pedal being too narrow but me being a worse pilot than I thought
I'll check the position of the pedal, I think it's not completely seated under the carpet.
Though, it might be good for some of you!
So I made some modifications, and it is available for you!
The first one will pay the cost price because I updated the file, and it is now a "beta" product.
Don't worry, it is 100% printable!
here is the link: Pedal Extension (SLZEAQCA2) by Ben006
Ben.
1982 928 S Euro
Old 05-17-2016, 04:27 PM   #6
Ben-Auto-Design
Ben006's Avatar
Hi guys!
It's been more than a month, and the extension has performed pretty good so far, I've gotten use to it and I like it now
Ben.
1982 928 S Euro
