Old 10-21-2015, 08:30 AM   #1
Boxster 986 hard top mounting bracket/plate removal.
986. 561.653.04 and 986.561.053.00
Hi
I have sourced a replacement for the broken mounting plate bracket, I have to replace a damaged left side hard top mounting bracket/plate part 986. 561.653.04 and 986.561.053.00 porsche (typical) but I have sourced a replacement for the broken mounting plate bracket.
I have contacted my local Independents and they have quoted me just to access the plate ,removal of the softop roof between 4-6 hours labour,before they can access the plate to remove it and bolt the new plate on!and replace the roof.
Has anyone on this forum replaced one of these?Do you need to remove the roof? If that is the case, is 4 hours labour really realistic, or are they taking the piss.Is it a straightforward enough process?
Cheers.
marks44 is offline   Reply With Quote
