Old 09-11-2015, 10:14 PM   #1
jc986's Avatar
convertible top motor trouble
So I had the typical problem with plastic ball cups breaking under stress on the push rods. Got new ones on, that was the easy part.
Reconnected the clam shell and tested the motor and transmissions - they worked fine putting the clam shell into the 'top down' position.
BUT.... when I tried to press the button up for the 'top up' position, the transmissions would not turn in the opposite direction like they were supposed to. They still kept turning forward, locking the clam shell down tighter.
I had to disconnected the cables and back them off with my drill.
Has anyone else had this problem?
So far, haven't tried to reconnect the clam shell and give it another try. Don't want the same thing to happen again.
So why did pushing the 'top up' button result in the transmissions still wanting to turn forward and pulling the clam shell down so tight???
They should have turned opposite direction to raise it but they didn't
97 Boxster 2.5L
07 Mercedes C230 Sport
jc986 is offline   Reply With Quote
Old 09-11-2015, 10:55 PM   #2
Old 09-12-2015, 03:34 PM   #3
jc986's Avatar
thanks particlewave, but it didn't fix the problem
97 Boxster 2.5L
Old 09-12-2015, 03:45 PM   #4
This is not a DIY Project Guide, so does not belong here.
Please post questions in the General Discussions or Performance and Technical Chat section for faster results.
Thank you!
Old 09-12-2015, 07:40 PM   #5
jc986's Avatar
Gotcha, thanks!
97 Boxster 2.5L
