Old 08-18-2015, 12:06 PM   #1
jpc763's Avatar
Car leveling and oil change
I am about to do my first oil change and have read that the car needs to be level in order to drain the most oil out.
I have ramps and jack stands. The ramps will raise the front of the car 8" while the jack stands will raise the back 11.5"
Will that 3.5" be an issue?
I *did* do a search and looked at Pelican Tech Articles as well. Great info on the actual change but nothing about raising the car.
2001 Boxster S - Midnight Blue Metalic
jpc763 is offline   Reply With Quote
Old 08-18-2015, 12:19 PM   #2
epapp's Avatar
I have never once worried about being totally level when changing my oil...I jack up the rear, give enough space with jack stands to get under there, drain and fill. I can't be really missing that much oil by doing it this way - it still takes 9 quarts to fill it up to the correct level again!
Old 08-18-2015, 12:20 PM   #3
JayG's Avatar
My understanding is the the car should be level to properly drain all the oil. A full change is ~9.5 quarts
Best to get 4 jack stands. I do the front of the car by putting the jack at the rear jack point, it will raise the entire side. I do one side and then the other. Then for the back i use a the rear jack point at shown in the Pelican DIY and it will raise the entire back so you can slide in jack stand for both sides
Note that the car should be warmed up and the oil will be hot when draining. You should let it drain for at least 30 minutes
Old 08-18-2015, 12:35 PM   #4
Bro, you're so poor you can't even afford to pay somebody to change your oil, and have to do it yourself?
Anyway, like he said. Best is car level, and warm oil when draining. But personally, I just raise the rear to change it, and sometimes the oil is cold too. If you don't feel comfortable knowing that you didn't completely drain all the oil, then get the car level.
hancock1701 is offline   Reply With Quote
Old 08-18-2015, 12:46 PM   #5
JayG's Avatar
I'm so poor, I filter the oil with used coffee filters and then reuse it
Where in So Cal are you?
Old 08-18-2015, 01:29 PM   #6
I'm in Orange County, but I also frequent San Diego County.
Old 08-18-2015, 01:41 PM   #7
epapp's Avatar
I even mixed mobil 1 and redline the other day to make up for the lost oil while replacing a broken drain plug!
Don't tell my IMSB!!!!
Old 08-18-2015, 01:58 PM   #8
I literally raise the back end all of an inch or 2 to change the oil, so it's fairly level.
It only needs to come up a bit to fit the catch pan under there, otherwise I wouldn't raise it at all. The drain plug and filter can be reached easily without getting under it.
Old 08-18-2015, 02:16 PM   #9
911monty's Avatar
Here is a picture of the internals of a stock oil pan. As you can see having the rear higher than the front is desired due to the channels into the baffle. Rear low or unlevel side to side would trap much more oil. When I dropped this pan I had the rear on ramps approx 4" higher than front and had less than 1/2 cup residual oil after draining.
Old 08-18-2015, 02:37 PM   #10
JayG's Avatar
good to know
So just raising the rear is actually better than level?
Old 08-18-2015, 02:40 PM   #11
JayG's Avatar
You should come down for some of the San Diego PCA events. We have a great group of owners and have a lot of fun
Thee is a back road tour coming up on Aug 30. We usually get between 80 & 125 cars
Driving Tour – starts at TBD | Porsche Club of America San Diego Region
Great 3-3,.5 hour round trip drive
The start and end locations as well as the rout changes each time
PM me if you will be going and we can say hi
Old 08-18-2015, 02:42 PM   #12
911monty's Avatar
good to know
Well I believe a picture is worth a thousand words! The only channel into the baffle is from the front. From there into the depression for the oil pump pickup and into the relief for the drain plug. So IMO PW's 2" height is ideal. I have a slope in my driveway, so I put front wheels up slope and rears on ramps. Plenty of room to drain and inspect bottom of car!
Old 08-18-2015, 02:50 PM   #13
JayG's Avatar
Gonna have to get some ramps
Old 08-18-2015, 03:17 PM   #14
911monty's Avatar
Forgot to attach earlier.
Old 08-19-2015, 05:32 AM   #15
Multi-Boxer Driver
Deserion's Avatar
I set my jack stands so the car is level. It gives me enough room to get myself underneath to inspect as well.
Thanks for the oil pan pic.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 08-21-2015, 10:25 AM   #16
Ben-Auto-Design
Ben006's Avatar
I did it on ramps, and I've got all 9+ quarts out
You never get all the old oil out anyway.
Ben006 is offline   Reply With Quote
