Old 07-19-2015, 05:35 PM   #81
oldskool73's Avatar
Further to my previous post, have been puzzling over the circuit diagrams, wondering if I'm on the right lines...
1. My kit came with a siren and a wire to run to it, but it's a bit big to fit under the seat so I was wondering if I could instead use it to get the horn to sound? Any idea if this would be possible by splicing into a wire in the bundle, and if so which one?
...looks like I might be able to splice onto the BK/YE 'alarm horn' wire, although as mine's only an M531 not sure if I'd even have the physical 'alarm horn' fitted?
2. Any idea if there's a wire I can splice to get a 'key on' signal, or might I have to take this from the fuse box?
...possibly BK/BR 'Term 15 In'?
3. There doesn't seem to be a combined 'door open' signal. I currently have it hooked up to just the drivers door, any idea how I could go about combining the separate door open signals into one 'either door is open' signal? (I'm guessing some kind of relay, but a bit out of my depth...?)
...according to Car Security and Convenience Alarm Sensors and Triggers I should be able to combine the 2 negative door inputs in parallel with just a couple of diodes?
Also, anyone know what the BL/RE(/BK) 'door safe' wires are? I'm currently using the BR/GN(/WT) 'claw blank' wires for door open indication, is this correct?
I guess the answer to all of these is just 'try it and see', but hoping someone with more knowledge than me might help me avoid frying something in the process
Thanks again.
oldskool73 is offline   Reply With Quote
Old 07-20-2015, 06:08 AM   #82
Yes, it means you will no longer be able to unlock the car with the key at the door
Something is not right.
Just read your message and went out to check. Unlock works as it did before - what that means is that the drivers side locking mechanism has been broken for a while. When necessary, I would just lock/unlock from the passenger's side.
One thing that prompted me to investigate keyless entry was the passenger locking mechanism was beginning to get tricky.
It is baffling that I can just cut the brown/red wire and have one side no longer connected.
AtlantaBoxster is offline   Reply With Quote
Old 07-20-2015, 06:09 AM   #83
Big thanks to particlewave and healthservices for helping me work through the issues and get my keyless system working!
Old 07-21-2015, 01:24 AM   #84
oldskool73's Avatar
Re my Q3 below, turns out it's easy to get a combined door open signal with a couple of one way diodes wired up to each door input as described in the link in my previous post. Still interested in any info on the other questions though...
TIA!
Old 08-17-2015, 07:31 AM   #85
Swhitcomb's Avatar
Ok, I finally had enough of the lack of a remote and looking like an **************************** every time I don't walk over and let my wife into the passenger side because it can't be unlocked from outside the car, and ordered a central locking unit. It should be here this week. I was researching wiring on an 02 and found this.
http://www.alarmsellout.com/support/diagrams/vehicle/PORSCHE%20BOXSTER%201997-2002.pdf
I would like the parking lights to flash, and I'm pretty sure there is a wire in the immobilizer for both left and right. Anyone know which wire I am looking for? If not I can trace it down, but knowing off hand would make it a heck of a lot easier. Also plan on making the trunk work. I'll have to read up more on that.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Swhitcomb is offline   Reply With Quote
Old 08-17-2015, 07:54 AM   #86
JayG's Avatar
Making the horn honk when armed would be best. Better than having to look for light flash
Old 08-17-2015, 08:10 AM   #87
Swhitcomb's Avatar
I could be happy with that too. Or, even both. The horn however, is all the way up in the column and I'm not sure there's a horn wire running to the immobilizer. If there is, I'll hook both of them up.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 08-17-2015, 10:50 AM   #88
At the immobilizer on 2001 and up:
Turn signals left = Black with White stripe, turn signals right = Black with Green stripe.
Alarm horn = Black with Yellow stripe.
Old 08-17-2015, 12:59 PM   #89
Swhitcomb's Avatar
That's exactly what I needed. Thank you sir.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 08-20-2015, 08:08 PM   #90
Swhitcomb's Avatar
Well, I got my module today. Tried to hook it up in the dark, which didn't work out too well. It locks with the unlock key, and won't lock at all. I think I may have reversed the wires. Not sure. I'll check in the AM.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 08-21-2015, 06:34 AM   #91
Swhitcomb's Avatar
Well, got it to lock and unlock properly. The wires were labelled wrong on the schematic of the controller. Confirmed it with a multi tester. They were backwards. Also had taped into the wrong red and brown wire.
Now I'm having a problem where once the alarm engages I can't get it to unlock with the remote. Also couldn't figure out the trunk so I saved it for another day. This car really frustrates the living **************** out of me.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 08-21-2015, 10:40 AM   #92
Odd. Does this happen when you use the key in the door?
If you have it all wired correctly, locking/unlocking with the remote is no different than doing it with the key in the door.
How are you powering the new unit?
Old 08-21-2015, 12:11 PM   #93
Swhitcomb's Avatar
It's wired right into the imbolizer. Power coming from it, grounded at the ground lug under the seat, and tied into the imobilzer for the lock unluck signal. Couldn't manage to get the truck to open with the unit so I gave up. I'm beyond frustrated with this car.
When you turn the key sometimes it unlocks both doors, sometimes it doesn't. I'm betting it's going to need work on the imobilzer which is going to piss me off.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 08-21-2015, 12:14 PM   #94
Which immobilizer wire did you tap for power?
Old 08-21-2015, 12:30 PM   #95
Swhitcomb's Avatar
The one under the seat.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 08-21-2015, 12:39 PM   #96
Swhitcomb's Avatar
http://youtu.be/5Eqb-DOoauM
Before the alarm kicks on it works fine.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 08-21-2015, 12:58 PM   #97
I was wondering which wire specifically because it may be a wire that is inactive once the system is armed. In other words, the power to the 3rd party keyless entry may be powered down once the system is armed.
I guess if the lock function still works when armed, then probably not.
When unlock with the new remote doesn't work, does the key in the door still unlock both doors (even if just occasionally)?
Old 08-21-2015, 01:18 PM   #98
Swhitcomb's Avatar
I'll have to check that. The lead that runs to the DME is live all the top. If you put the top down, or sit in the car and activate it you can hear it clicking and the lights flash, just won't unlock the car.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Old 08-21-2015, 01:26 PM   #99
For locking and unlocking, you are using the brown wire with the white stripe and the brown wire with the red stripe, correct?
Old 08-21-2015, 02:02 PM   #100
Swhitcomb's Avatar
Yes. Brown and white and brown and red.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
