Old 03-03-2015, 05:09 PM   #1
Ben-Auto-Design
Ben006's Avatar
For now the list is this thread
I'm still waiting for some hardware (from various places, to see wich one will be the best, that's why it takes some times).
Ben
Ben006 is offline   Reply With Quote
Old 03-06-2015, 10:01 AM   #2
Ben-Auto-Design
Ben006's Avatar
Hi !
Two more parts to get and I can test the T ! I can't wait !
The nuts fit in as designed
I will test it on a dyno the 11th of ... April ... It's a month to wait, but it's the only time I can dyno it. during my school car show !
Old 03-17-2015, 08:09 PM   #3
Need For Speed
KRAM36's Avatar
Anymore pictures to share? I'm very curious on what you have going on. I need a different distribution T and the 997 Distribution T is too big, it also has this thick piece I marked in red that hits the top of my starter and I can't get a good down angle on the TB.
I really don't want to change the intake as the car is running like a beast right now. I suppose I could take it back out, shave off that area and reinforce it by melting some wire into it.
2003 Boxster S
Old 03-19-2015, 03:20 PM   #4
Ben-Auto-Design
Ben006's Avatar
now I'm stuck on the testing because I have no place to work :/
I don't need to do much, but I can't do it at home because my 93YO neighbour will report me for doing so ...
Monday a friend should lend me is garage for few hours and I will finally get this thing done !
The only thing I did is a little sanding to smooth the outside and got the EVAP port enlarged a little.
I hate wasting my time like that, waiting.
If anyone want's to offer me a little clean place to work at for a few hours, he's welcome
Old 03-19-2015, 09:32 PM   #5
98 Arctic silver 986
tommy583's Avatar
This is an interesting thread. Being that I have a non e-gas model the only way I can find to get a larger throttle body is the Pedro's bore service. His site says they bore the stock one out to 75mm. So if I do this I would be in the market for one that would fit that. Is that a possibility?
Old 03-20-2015, 02:33 PM   #6
edc
550 Anniversary
edc's Avatar
Non e-gas 3.4 911 throttle body.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
Old 03-20-2015, 04:07 PM   #7
tommy583's Avatar
Thanks edc, I was thinking this would work as well. But I was unable to find one online last night to be sure.
Old 03-20-2015, 04:50 PM   #8
Reebuck1
Size
Kram36....What size engine are you running?? 996 3.4 or 3.6?? and what size throttle body are you using?? Thanks....I too am waiting to see how Ben does !!
Reebuck1 is offline   Reply With Quote
Old 03-20-2015, 07:42 PM   #9
Need For Speed
KRAM36's Avatar
Stock 3.2, 76mm TB.
2003 Boxster S
Old 03-20-2015, 06:48 PM   #10
Ben-Auto-Design
Ben006's Avatar
Yes I can do one for the 2.5 too, but since the 2.5's plenum is very different from the 2.7 and 3.2's plenum I will need to take the mesurement from a 2.5L one
My friend told me Monday, I hope I will be able to do it and that all my measurement were right !
cross your finger with me
Old 03-25-2015, 11:48 AM   #11
Ben-Auto-Design
Ben006's Avatar
Hi !
As planned I found a garage Monday to finally work on the intake !
and... it doesn't fit ... nothing bad, but the straight T shape makes the TB bump against the starter and force the intake elbow to stick too far up.
Nothing that a slight angle can't fix
I will make another one soon.
I also noticed that the temperature in the engine bay was higher than I thought on a hot Florida day !
So I put the T back into the oven to see if it can handle 240F ... result, it can I will just make it thicker in some place for added strengh and peace of mind !
It takes time, but I'm on the right way
Ben
Old 03-25-2015, 12:59 PM   #12
Ben-Auto-Design
Ben006's Avatar
I also think that I will try a flow divider like in the 987 :
without the flap, but it's a great way to ensure that both sides receive the exact same amount of air despite having to make a tighter turn on the left side !
Old 03-25-2015, 04:13 PM   #13
Need For Speed
KRAM36's Avatar
Curious why the air is making a tighter turn to the left side?
2003 Boxster S
Old 03-25-2015, 06:23 PM   #14
Ben-Auto-Design
Ben006's Avatar
because I'm not going tu use a straight T shape any more, it will be tilted 10°
I will show you as soon as I'm done with the software.
The shape will look weird, but I'm trying to direct air equally on each side, not that easy ...
I'm going to try another route, like the oem (longer tube after the TB), and see if I can come up with a better, more balanced shape
also, the problem with a big divider is that it's going to "seal" the to banks from each other, and makes you loose top end power (sorry, I lack technical vocabulary to explain it correctly in english).
So ... I'm working on it
If anyone has any idea, feel free to share
Ben
Old 03-25-2015, 06:37 PM   #15
Need For Speed
KRAM36's Avatar
TRK (The Radium King) would probably be the one to consult on that.
2003 Boxster S
Old 04-02-2015, 08:43 AM   #16
Ben-Auto-Design
Ben006's Avatar
Hi !
I made modifications to the T, with an angle, the TB should point slightly to the left.
this way it should clear the stater solenoid.
Now I need to see if the engine cover will clear the intake elbow.
I want to get it 100% right before printing it.
Old 04-02-2015, 08:59 AM   #17
Engine Surgeon
Remember, the short radius is what matters with any normally aspirated engine. I see people wasting their time with induction components, because they don't understand how dry flow really works.
US Patent 8,992,089 &
US Patent 9,416,697
Old 04-02-2015, 05:16 PM   #18
Ben-Auto-Design
Ben006's Avatar
Yep
But the space is tight, and the TB is really bigger than the 986 one, so I try to find the best shape with the room I have.
Old 04-20-2015, 01:43 PM   #19
Ben-Auto-Design
Ben006's Avatar
Hi !
I did have a lot of free time to work on the intake, but I think this time I'm good !
I realise that trying to make it simple in shape ... would making it harder to fit ...
So I copied the stock shape. It took me some time to get the angles as clos as possible to the stock T, but I think I'm close.
This way, It will clear the starter solenoid, and the engine cover
tell me what you think
Ben
Old 04-20-2015, 06:44 PM   #20
Reebuck1
T body
Great Ben!! When will you be able to make a few??
What material will you use (heat sensitivity)?
