Old 03-25-2015, 06:23 PM   #14
Ben006
Ben-Auto-Design
Ben006's Avatar
because I'm not going tu use a straight T shape any more, it will be tilted 10°
I will show you as soon as I'm done with the software.
The shape will look weird, but I'm trying to direct air equally on each side, not that easy ...
I'm going to try another route, like the oem (longer tube after the TB), and see if I can come up with a better, more balanced shape
also, the problem with a big divider is that it's going to "seal" the to banks from each other, and makes you loose top end power (sorry, I lack technical vocabulary to explain it correctly in english).
So ... I'm working on it
If anyone has any idea, feel free to share
Ben
Ben006 is offline   Reply With Quote
