07-21-2019, 09:58 AM
#641
They should be where next week ???
07-22-2019, 10:57 AM
#642
Ben-Auto-Design
At my place so I can control them and machine the shafts
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
07-22-2019, 02:20 PM
#643
Like a glacier we are slowly moving forward ! Looking forward to be able to purchase 😊
07-28-2019, 09:15 AM
#644
Ben-Auto-Design
1982 928 S Euro
07-28-2019, 11:05 AM
#645
Looking good ! I'm assuming you will announce on here when these will be available to purchase ?
07-28-2019, 01:03 PM
#646
Quel prix quand ils sont disponibles à la vente? En USA.
07-29-2019, 03:57 AM
#647
Will these work with the eBay shifter?
07-29-2019, 01:46 PM
#648
They should since Ben's shifter is a modified eBay knockoff of the B&M short shifter. But if you're going to the trouble of taking out your console and disassembling your shifter, why not also go for the bolt action ball bearing smoothness of Ben's shifter?
07-29-2019, 03:01 PM
#649
I originally wanted one of his but he was unable to provide one at the time. I went with the Ebay one instead. A little less side to side slop from my eBay shifter would make me happy and if it fits...
Reason: Clarity
07-31-2019, 10:07 AM
#650
Ben-Auto-Design
Hi !
Yes it will fist almost any short shifter, and soon even the stock shifter with the addition of a small bushing.
They are almost ready ! I need to pack them and send them out to Uniwerks !
I ran into a "problem" though...
I thought I could machine the shouldered bolts cleanly, but it's very hard to make something that works great, looks clean, and that I can make 200 of without having to quit my job
It's no big deal though, the only difference is that a 10mm hole needs to be drilled to make room for the threaded part of the bolt.
Here it is, cut bolt :
Normal bolt :
Ben
1982 928 S Euro
07-31-2019, 02:03 PM
#651
Ben,
I'm not sure I understand what you are saying here:
"It's no big deal though, the only difference is that a 10mm hole needs to be drilled to make room for the threaded part of the bolt."
Does this mean you are drilling a 10mm hole for the bolt or is this a hole I need to drill when I install the lever? Where does this hole need to be drilled? Why is the bolt cut? Do I need to drill a 10mm hole and also cut the bolt? I'm unclear on what is required to make this work.
Maybe you can clarify.
Dana
08-01-2019, 03:22 AM
#652
Ben-Auto-Design
Just drilling a 10mm hole for the threaded part of the bolt to go through because it’s too long and I can’t cut them cleanly.
I’ll be writing instructions tonight
1982 928 S Euro
08-02-2019, 04:15 AM
#653
I’ll take one as so as they’re ready, please let me know when they’re ready.
08-02-2019, 09:15 AM
#654
I guess Dremeling off the tip of the bolt will be an acceptable alternative?
08-03-2019, 08:55 AM
#655
Ben-Auto-Design
They are shipping to the Uniwerks Design on Monday
Yes, you can cut the bolt yourself if you prefer that over drilling a hole !
Soon, I'll be fitting a full kit on a 996 GT3 Cup car
1982 928 S Euro
08-03-2019, 08:57 AM
#656
How much are they going to sell for?
08-03-2019, 11:41 AM
#657
^^^ Well done sir  Looking forward to purchasing and installing . Thanks for making this happen .
08-05-2019, 02:33 AM
#659
Ben is any kind of lubricant/grease suggested for any of the pivot points ? Or just install dry ?
08-05-2019, 02:51 AM
#660
Ben-Auto-Design
No, grease is definitely required for longevity !
Any high pressure grease will do. No copper/aluminum paste.
I just dropped the package right now
1982 928 S Euro
Thread Tools |
Display Modes |
Linear Mode
