Old 08-14-2015, 04:27 PM   #4
jc986's Avatar
Originally Posted by Angel911 View Post
The overhead release latch on My 2001 Boxster convertible popped slightly open while I was driving causing the windows to open as if I was going to open the top. The top edge of the convertible top now sits about 1/4 away from the top of the window...the problem:I cannot push the release button to pull down the latch or push it back into the closed position because the top has slipped back enough that it allows no slack to perform either of these steps. It is stuck and i do not want to apply to much force to try and open or close it. I somehow need to slide the top forward enough to release the latch fully. Anyone ever have this happen?
I had this happen too. Easy fix, you just have to take two screws out of the base plate that the latch seats into. The screws are actually torx fasteners, you can access them by popping out the two black plastic "eyes" on either side of the cabin light at the top of the windshield. Once they're out, you can move the plate toward the back window and this should release the stuck latch. Then you can put the torx fasteners back in and latch the roof properly.
97 Boxster 2.5L
07 Mercedes C230 Sport
jc986 is offline   Reply With Quote
Tags
convertible top , release lever stuck
