11-19-2015, 10:35 PM
#121
Happy to make you one
Paypal me $45 as a gift , let me know the year Boxster and I can get you one out in a frew days...since you are doing switches and not a 4 stalk I will make the harness a few extra inches longer to give you some wiggle room for hookup
11-19-2015, 10:54 PM
#122
Sent it over. Thank you. Also sent a pm
11-27-2015, 06:07 PM
#123
Please PM me the year make of your Boxster
Dwight
12-02-2015, 08:24 AM
#124
Boxster OBC harness (Switch)
removed - accidental post
12-23-2015, 03:44 PM
#125
PM sent, I'm interested if you are still doing them
02-01-2016, 05:46 AM
#126
I purchased a nice 2001 Base Boxster just about a year ago. The OBC and Cruise Control were not activated. I recently picked up a re-conditioned Durametric Pro from Durametric. Very impressive and powerful tool.
I plan to hack the OBC and Cruise Control modules. I currently just have the 2-stalk switches on my steering column (i.e. wipers and turn signals); I will remove the 2 stalk switch and install the 4-stalk version. I know some folks use a panel mounted rocker switch for the OBC, but I like the OE look with the switches on the steering column.
I have contacted Dwight about purchasing one of his quality wiring harnesses for the OBC. I will make the Cruise harness myself.
Apparently there is an excellent guide to the OBC hack that was written by Joeisf (sp). Does anybody have a link, or a copy, to his hack instructions? That would be much appreciated. Thanks.
Regards, Bruce
'01 Boxster
'84 911 Carrera Sport
02-02-2016, 04:55 AM
#127
The Pelican website has a DIY also. I could not get to the link you speak of. I am also getting ready to do this hack and got the harness from Dwight. I am also doing the intermittent wiper hack, and the dash mounted rear wing switch, and 996 gauge cluster upgrade
99 Porsche Boxster
02-02-2016, 12:04 PM
#128
Made a pdf file of it sometime back
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
02-02-2016, 02:41 PM
#129
Perfect! Thanks Kent!
Regards, Bruce
'01 Boxster
09-11-2016, 09:23 AM
#130
Still making these harnesses?
'01 Boxster S (Bailey) Fabspeed Cat Deletes, Top Speed Muffler, Top Speed Short Shifter, Strut Bars, Lowering Springs
'02 Ural Solo (Nikita) GE Nighthawk LED headlight (RIP)
09-11-2016, 12:37 PM
#131
PD I have a 2002 S with 3 stalk and have purchased a 4 stalk setup. I plan on removing the 4th stalk from the one I purchased and adding it to my existing 3 stalk. I would like to purchase whatever the correct harness is to do the conversion. You can PM me the details and I will Paypal the funds. Thank you
09-12-2016, 02:47 PM
#132
Yes...sorry for the delay
I am still making the OBC harness assemblies. They look better than the ones that came factory. Right now production is running about 4 to 5 days before I can get you one in the mail. The current cost including shipping is $48 paypaled or you can send me a check. Let me know before you paypal me money....having problems with those folks.
or you can contact me at pdwight@att.net
Dwight
09-12-2016, 04:19 PM
#133
Dwight I sent you an email .
10-02-2016, 05:29 AM
#134
I want to post a follow up to my buying experience with Dwight . I purchased one of his cables about three weeks ago, he's in AL. and I am in Georgia. He sent me an email letting me know when he shipped. Over a week went by and nothing showed up in the mail. I sent Dwight an email letting him know it had not arrived. We agreed to wait three more days and I should get back to him. Three days went by and no cable showed up. He made up another one and shipped it out immediately. Guess what happened ? Both cables showed up on the same day ! It was obvious the first cable shipped sat in a post office somewhere for a long time without being looked at or moved. The bottom line of my story is Dwight was/is a stand up guy that backed up the sale with a 2nd shipment, it was NOT his fault USPS messed up the 1st shipment. I have contacted Dwight and will be shipping one of the cables back so he can help someone else in the future.
Thanks Dwight
10-02-2016, 05:45 PM
#135
Thank you for the kind words
I always treat people the way I want to be treated, many of our follow Boxster enthusiasts have helped me with many projects with Tools, parts you name it. I think all this good Karma will come back to help us all.
Good luck with that install and let me know if I can help in any way
Sincerely
Dwight
11-07-2016, 04:46 PM
#136
Confused about dash switches - 1 or 2?
Been reading a lot on this topic, and have found conflicting info as to the number of dash switches required.
Pelican tutorial says that two switches are required. But reading thru this thread, several folks mention using only one.
Can someone please walk me thru this?
For both cases, what happens, exactly, when the various switches are pressed? Which switch does what?
Thanks - DM
2000 Ocean Blue Boxster S
1980 Ferrari 308 GTSi
2019 Alfa Romeo Giulia Ti Sport AWD
11-07-2016, 08:36 PM
#137
Switches
I have made many OBC harnesses for a single switch and a few for two switches. I have never installed anything but the 4 Stalk assembly but I can add some data. A single switch will only let you step through the various views.....Temperature , MPG etc
Two switches should let you emulate a 4 Stalk and set the speed gong and reset some options....personally the 4 Stalk assemble just is not that expensive and I would go with what looks factory. 4 Stalks come up quite often for sale for under $150
11-08-2016, 02:24 PM
#138
1999 base
11-24-2016, 07:48 AM
#139
i need one of these...
01-27-2017, 02:53 PM
#140
2003 Base 5-speed
Hi Dwight,
I sent you a PM. I would like to purchase your wiring harnesses for the 4 stalk. I have a 2003 Base.
Thanks, Gary
