Old 10-02-2016, 05:45 PM   #1
Pdwight's Avatar
Thank you for the kind words
I always treat people the way I want to be treated, many of our follow Boxster enthusiasts have helped me with many projects with Tools, parts you name it. I think all this good Karma will come back to help us all.
Good luck with that install and let me know if I can help in any way
Sincerely
Dwight
Old 11-07-2016, 04:46 PM   #2
Dave80GTSi's Avatar
Confused about dash switches - 1 or 2?
Been reading a lot on this topic, and have found conflicting info as to the number of dash switches required.
Pelican tutorial says that two switches are required. But reading thru this thread, several folks mention using only one.
Can someone please walk me thru this?
For both cases, what happens, exactly, when the various switches are pressed? Which switch does what?
Thanks - DM
2000 Ocean Blue Boxster S
1980 Ferrari 308 GTSi
2019 Alfa Romeo Giulia Ti Sport AWD
Dave80GTSi is online now   Reply With Quote
Old 11-07-2016, 08:36 PM   #3
Pdwight's Avatar
Switches
I have made many OBC harnesses for a single switch and a few for two switches. I have never installed anything but the 4 Stalk assembly but I can add some data. A single switch will only let you step through the various views.....Temperature , MPG etc
Two switches should let you emulate a 4 Stalk and set the speed gong and reset some options....personally the 4 Stalk assemble just is not that expensive and I would go with what looks factory. 4 Stalks come up quite often for sale for under $150
Old 05-05-2020, 01:24 PM   #4
Dwight,
I sent you a PM asking if you're still making the harnesses.
Thanx,
Harry
1970 911T Hot Rod
2003 Boxster S
2018 Macan S
2021 718 Spyder
Balloonmeister is offline   Reply With Quote
Old 11-24-2016, 07:48 AM   #5
i need one of these...
geetee is offline   Reply With Quote
Old 01-27-2017, 02:53 PM   #6
2003 Base 5-speed
grc0456's Avatar
Hi Dwight,
I sent you a PM. I would like to purchase your wiring harnesses for the 4 stalk. I have a 2003 Base.
Thanks, Gary
Old 01-27-2017, 07:56 PM   #7
Pdwight's Avatar
OBC still available
I answered your PM
$48 shipped
Thanks for the interest .
Old 01-28-2017, 05:01 AM   #8
2003 Base 5-speed
grc0456's Avatar
Paypal sent. I PM'ed you my address. Thanks!
Old 11-18-2017, 03:10 AM   #9
Another one
Hi Dwight,
I sent you an email I would like to purchase your wiring harnesses for the 4 stalk too. I have a MY03 Base as well.
Thank you,
David
Tigger19 is offline   Reply With Quote
Old 11-19-2017, 07:48 PM   #10
Pdwight's Avatar
PM Sent
Check your message box
Old 02-10-2017, 03:01 PM   #11
auBoxster's Avatar
I'm keen on a cable / harness Pdwight - a PM is heading your way :-)
auBoxster is offline   Reply With Quote
Old 08-10-2017, 10:37 AM   #12
PM sent, thanks
Dave
1998 Boxster
1978 R100RS BMW Motorcycle 140K, 1 owner
WhiteyII is offline   Reply With Quote
Old 08-16-2017, 07:25 PM   #13
Pdwight's Avatar
A new Harness is
On it's way back to you
Dwight
Old 08-19-2017, 01:37 PM   #14
Dwight very nice harness, very professional work...... Thank you
Dave
1998 Boxster
