07-01-2015, 08:43 PM
#101
Yes I am
I make each one up by hand so after payment I can usually get you one in the mail is 3 to 5 days. Paypal me $45 as a gift and I will get you one on the way
07-01-2015, 09:04 PM
#102
Cable
Great, who do I pay pal that too?
SciGuy
2000 Boxster S (13K miles)
07-02-2015, 06:52 PM
#103
Sent, thanks
SciGuy
07-02-2015, 06:58 PM
#104
Thank you for your order
Will be in the works and out soon
07-09-2015, 08:55 PM
#105
On it's way....sorry for the delay
Thanks again
Dwight
07-13-2015, 08:29 PM
#106
Received cables today. Beautiful. Thanks Dwight.
SciGuy
07-13-2015, 08:46 PM
#107
Thanks, I appreciate the kind words
07-15-2015, 06:42 AM
#108
Embarrassing but I want to do this enough to say - I lost the instructions that came with my cable(dash switch version) and I don't know exactly how to install it. Has anyone done any install instructions that I missed? I know there was some talk about this.
Pdwight, do you have any pics that you can share for the likes of me please?
Thanks.
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
07-15-2015, 07:50 AM
#109
There Is No Substitute.
If you PM your email, I can send you a PDF of the original build/install instructions from yosief.
09-11-2015, 11:42 AM
#110
Has anyone installed using the dash switches to control the OBC features? When reading the instruction on the Pelican website it states "To use this switch with the OBC, wire pins 2,3,4,5 from the table above to pins 1 and 2 of two different switches, and then connect the green ground wire to pin 4 of both switches." - This would mean you need 2 switches correct? Would you also need two of the white harnesses from Dwight?
2001 Boxster S Arctic Silver : LN IMS Retrofit, Sport Package, AUX cable mod, de-snorkeled.
09-11-2015, 12:52 PM
#111
I think you need 2 switches to simulate "up-down" and "front-rear".
1 harness should suffice, like for the stalk addition.
2006 V6 Mustang
2008 ML 350
09-11-2015, 01:44 PM
#112
Thanks for clarifying.
09-11-2015, 03:50 PM
#113
Have to be honest with you
I would go with a 4 stalk, they just do not cost that much and look factory...you can do it with one switch and just step through the displays...I can make you as harness either way you go.
Dwight
09-11-2015, 08:50 PM
#114
Would someone be able to confirm that the OBC stalk from a 4 stalk part number 99661321910 for a 911 or a 996 would work for the 986?
09-11-2015, 08:52 PM
#115
Yes, they should work for the 986.
2006 V6 Mustang
2008 ML 350
09-16-2015, 08:20 PM
#116
SciGuy
09-17-2015, 12:02 PM
#117
Dwight, I sent you a PM.
2001 Boxster S - Midnight Blue Metalic
11-19-2015, 10:07 PM
#118
Harness
Hello,
Are you still selling this?
Would it be possible to make a harness that goes to 2 switches?
Rj thomas
rj.thomas93@gmail.com
11-19-2015, 10:19 PM
#119
Yes, I am still making these. So you want 5 conductors with leads for two switches ?
Would you simply like push on female crimp connectors (I will of course solder as well as crimp)
11-19-2015, 10:30 PM
#120
Yes, I think so. So that would be 4 signal and 1 ground leads?
Yes push on crimps are great for the switch end.
