Old 09-11-2015, 12:52 PM   #111
EJ-Fresno
EJ-Fresno's Avatar
Originally Posted by 01BOXYS View Post
Has anyone installed using the dash switches to control the OBC features? When reading the instruction on the Pelican website it states "To use this switch with the OBC, wire pins 2,3,4,5 from the table above to pins 1 and 2 of two different switches, and then connect the green ground wire to pin 4 of both switches." - This would mean you need 2 switches correct? Would you also need two of the white harnesses from Dwight?
I think you need 2 switches to simulate "up-down" and "front-rear".
1 harness should suffice, like for the stalk addition.
2003 2.7 Boxster - Tiptronic - Carrera wheels - OBC - Red calipers - Cat pipes - Modified muffler - Rear speakers - K&N - Litronics
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
