Old 07-02-2014, 03:08 PM   #41
rdass623's Avatar
I am not really sure how long the leads should be, but my guess would be roughly the same length. the distance the wires should travel looks like it would be about the same, perhaps add 6 inches or so for safety sake. just guessing here
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
Old 07-06-2014, 10:40 PM   #42
Pdwight's Avatar
Question for the Non 4 Stalk
Will a regular push on terminal fit the porsche dash switch you are going to be using...I am ready to start making up cables..all my stuff finally came in.
Old 07-07-2014, 01:31 PM   #43
Pdwight's Avatar
Another question
If you are using the ondash switch instead of the 4 stalk do you only need 2 wires and a ground ?
If so I can do the cable for a better price
Old 07-07-2014, 08:12 PM   #44
rdass623's Avatar
the switch I am planning on using is just a window switch. so two leads and a ground should be fine, because the illumination of the switch will not be used (it would be too confusing for people to see the window diagrams on the dash).
Old 07-15-2014, 07:43 AM   #45
Hi all,
beacause my car has the board computer i took some photos, so you can see what the cable will add.
Exterior temperature:
Average speed:
Average fuel consumption:
Remaining range:
Regards from germany
Markus
Old 07-15-2014, 11:47 AM   #46
lkchris's Avatar
Get it while it's hot!
Porsche 911 996 986 Boxster Signal Wiper Cruise Computer Switch 99661321900 | eBay
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 07-15-2014, 12:59 PM   #47
Pdwight's Avatar
Whata deal
It even has the arm "washer" that you have to order that is like a 18 dollar part for a piece of rubber.
