Old 05-06-2014, 02:39 AM   #21
eicheldp's Avatar
Thanks for your help.
2004 Boxster S
eicheldp is offline   Reply With Quote
Old 05-08-2014, 08:53 AM   #22
inveniam viam aut faciam
Does anyone have a picture of the '03 or '04 cluster with OBC enabled? I just installed a cluster from an '02 S with OBC and a new four stalk column switch in my originally non-OBC '03 S. It works fine and the '02 OBC cluster has a dot matrix LCD display with higher res than the '03 cluster. I don't see how the '03 non OBC cluster would show all the information that the OBC cluster does...
Qmulus is offline   Reply With Quote
Old 05-08-2014, 09:42 AM   #23
WALDMEISTER
BRAN's Avatar
MY01 (-02) Boxsters have no DOT-Matrix OBC displays.
Boxsters/996 MY03-04 do have DOT-Matrix OBC displays.
--> I switched from a MY01 Boxster to a MY04 996 gauge cluster.
Old 05-08-2014, 10:01 AM   #24
Pdwight's Avatar
Got my OBC Stalk in
I got the entire assembly with all the stalks for $125 from OklahomaForeign.com....looks like new
Thanks Pjq
Old 05-08-2014, 10:06 AM   #25
Pdwight's Avatar
What is that bid "S" switch on your dash there ?
Old 05-08-2014, 10:29 AM   #26
WALDMEISTER
BRAN's Avatar
That is my custom made "Sprint Booster" switch:
"S" unlit/off = factory throttle response
"S" green = sporty throttle response
"S" red = agressive throttle respone
Old 05-08-2014, 10:54 AM   #27
Pdwight's Avatar
Tell me more ...please
Old 05-08-2014, 11:19 AM   #28
WALDMEISTER
BRAN's Avatar
There are a few solutions on the market,
Sprint Booster was probably the first out there:
SprintBooster by BoulekosDynamic
Definitely worth every penny, imo
Old 05-08-2014, 11:31 AM   #29
WALDMEISTER
BRAN's Avatar
...here the old MY01 OBC enabled Boxster gauge cluster (non-DOT-Matrix)
Old 05-08-2014, 11:40 AM   #30
OK, so when people activate the OBC on a car without the dot matrix cluster, what do they get? My original cluster does not have the dot matrix display.
Any yes, we need more info on the S button...
I also want to find a 996 cluster with white display for my '03 S. If anyone has any leads on one for a reasonable price, please let me know. I have come up empty handed.
Old 05-08-2014, 11:46 AM   #31
Oops, a bit too late on that last one. It looks like BRAN answered the questions already...
Old 05-09-2014, 04:42 AM   #32
heliguy's Avatar
Yes...more about this magic S button.
Old 05-09-2014, 08:32 AM   #33
WALDMEISTER
BRAN's Avatar
not a biggie, just a magic "S"print Booster switch...see above somewhere
Improves per gallon
Old 05-09-2014, 09:34 AM   #34
heliguy's Avatar
Can you give us a quick write up on your Sprint Booster installation? Particularly the button you use to activate the different modes and the way you wired it.
Old 05-09-2014, 03:08 PM   #35
WALDMEISTER
BRAN's Avatar
I can try, too bad I have no photos anymore:
1.) Installation was a snap, "theoretically".
All you do is disconnect the ECU gas pedal connector from the harness and plug the Sprint Booster in between.
2.) Without disassembling the driver side dash, duct work, etc....locating the ECU gas pedal connector was, let's say, a challenge.
3.) The cable length of the harness/connector is JUST okay to squeeze the Sprint Booster in between.
4.) I was able to install it by deinstalling the duct work underneath the dash, lots of led lights, patience and a sore back
5.) I heard of a guy, using a PORSCHE switch, soldering bridges, cutting away connection lines etc., being able to link both smd-boards of the switches. Looked 100% OEM as his PORSCHE switch (using the amber/red LED) was operating the Sprint Booster switch.
6.) I tried to figure out, how he could have done it, but wasn't able to, so I went down another road and did a mechanical solution, as the smd-boards are almost identical in size. I was able to open and modify the PORSCHE switch to hold the Sprint Booster smd-board (instead of its original board) while using its super bright green/red (btw. the smd-LEDs seem identical, so one could change the green to the spare amber LED) LEDs to illuminate "ze MAGIC S" (sanding down the black layer, create an "S" ouline, clear coating on top, done). The switch is functional and its LEDs are powered by the ECU gas pedal connector.
pelicanparts and Wayne's 101 Projects book have good information about it, too.
Old 05-21-2014, 07:13 PM   #36
pjq
So as a follow up to the earlier post, I was at the indy shop today (european auto surgeons, Maine) and they turned the OBC and Cruise Control on. It took Aaron all of about 15-20 min and in his test drive everything worked as it was suppose to. He then flushed the transmission oil and brake fluid for me. They have a good shop and do good work.
On the 4.5 hr drive home I used the cruise on the interstate and was surprised how well it held the speed I set, with little fluctuation.
The OBC, I got my outside temperature and a lot of other paraphernalia. I tried playing with it a bit on the way home but then decided the road needed more of my attention.
An unexpected outcome of having these 4 stocks is I now have to be careful with my knees. I'm 6' 1" and 32" leg inseam I've hit those stocks getting in or out of the car.
So in conclusion, follow the books and the info on Renntech.org and it should all work out. Its not a real difficult project for a 2003 -04.
Old 05-22-2014, 11:00 AM   #37
Hi There,
Where did you run your ground wire for the OBC? My panels look like they're painted so I'm wondering how good it is. i was thinking of sanding the paint off the panel the screw but I figured I'd see what you did. In the Pelican Parts article, the panels look like they're unpainted aluminum.
mctigercom is offline   Reply With Quote
Old 05-22-2014, 11:43 AM   #38
danch's Avatar
That's strange, I have the 3.2 S but no dot matrix display Al La picture : Name:  uploadfromtaptalk1400784249021.jpg
What's going on here as I'm about to add the OBC loom & switch
Any idea's ?
danch is offline   Reply With Quote
Old 05-22-2014, 11:58 AM   #39
Pdwight's Avatar
Install the stalk
OK I have my stalk, my Tech turned the function for OBC on when he did a diagnostic of the car after my wreck....how difficult is it to install the OBC Stalk ??
Dwight
PS Danch , you have the same display I do
Old 05-22-2014, 12:07 PM   #40
danch's Avatar
Dwight
Just the obc stalk takes about 20 minutes for a first timer like me, got to install the loom I made next & then get the obc function turned on but I'm doubting things now as my display doesn't look like the others
Cheers
Dan
