Old 02-19-2014, 08:40 PM   #1
jc986's Avatar
Ignition sticking
Starting to notice the ignition is getting harder to turn every time I put the key in. Already did the key lube trick, was working ok but now seems harder to turn. Anyone have any ideas or suggestions for this?
jc986 is offline   Reply With Quote
Old 02-19-2014, 11:06 PM   #2
RawleyD's Avatar
Sure. A new ignition switch
:ah:
Old 02-20-2014, 04:24 AM   #3
kjc2050's Avatar
What RawleyD said. You need to replace the electrical portion of your ignition switch. There are numerous helpful posts on this topic. Here's one I started; read it all the way through for how to DIY two different ways: http://986forum.com/forums/general-discussions/46411-ignition-switch-replacement-holy-crap.html
Old 03-17-2014, 02:50 PM   #4
right after I got my car I was a the car wash. when I went to start it again the key would not move to the start position. ended up being the steering wheel was turned to hard. turned it a little to release the tension and the key turned not problem. I think most cars will do this, but the boxster seems to be particularly prone to it.
kiyakubuke is offline   Reply With Quote
