Old 11-13-2013, 05:06 PM   #1
KylesBoxS's Avatar
Front Camber Adjustment
Hey guys, last time we went autocrossing, we had understeer (which may be normal) but at the end of the day only the outer edge of the tire was worn out. I want to change the camber a little to counter it, but I have no idea if it is adjustable, and if so how to adjust it. Any tips?
Lifes too short to NOT drive a Porsche.
KylesBoxS is offline   Reply With Quote
Old 11-13-2013, 08:38 PM   #2
com3dorm3's Avatar
Camber adjustment is possible, though it is limited probably to about .8 or .9 degrees (front) on stock suspension.
Fronts are adjusted at the top strut mount. Rears are via an eccentric bolt in the control arm.
You will need to adjust toe accordingly. Not too bad of a job if you have access to an alignment rack.
2000 Boxster S
com3dorm3 is offline   Reply With Quote
