Camber adjustment is possible, though it is limited probably to about .8 or .9 degrees (front) on stock suspension.
Fronts are adjusted at the top strut mount. Rears are via an eccentric bolt in the control arm.
You will need to adjust toe accordingly. Not too bad of a job if you have access to an alignment rack.
2000 Boxster S
