Old 11-01-2013, 02:21 PM   #1
HELP Opening Headlights
I'm trying to take apart my headlights and install new HID projectors but I haven't had any luck and I desperately need some help before I break something.
I've followed all the instructions I can find so far: baking for 10 min @ 225 and then trying to pry open the headlights. I've repeated this about 5 times now with no progress. I think the biggest issue I'm running into is that I don't know where I'm supposed to be prying. At the top of the headlight the only place I can see to pry is right against the headlight itself and I've been able to find some sort of a rubber/silicon gasket at the bottom but that doesn't seem to be doing anything either (see pictures). Can anyone please do a better job of describing where I should be prying and what should be happening when it's working?
Thanks in advance!
mayerstrat is offline   Reply With Quote
