I'm not sure how you would describe the tool I ended up using. I'll post a picture when I post install pictures tomorrow. The biggest trick for me was understanding that I should pushing away the bottom piece more then you're pushing up the headlight unit. I also ended increasing the baking time at a lower temperature (20 min at 200F) based on another thread that I found.
The inside is all painted, just need to dremel the hole tomorrow, install the unit and then re-seal the headlights.
