Old 08-29-2013, 03:43 AM   #1
More's Avatar
DIY For Transmission Oil Change?
It's time to check and change my Transmission Oil.
Can anyone recommend me a decent DIY?
1998 Porsche Boxster 986 Convertible.
More is offline   Reply With Quote
Old 08-29-2013, 04:40 AM   #2
i need one also, x2
I plan to put some motul into it for track
Paseb is offline   Reply With Quote
Old 08-29-2013, 10:16 AM   #3
It is a very simple process, if you have the correct equipment. Getting the drain plug out without the correct tool is a bear of a job. It is a 16mm triple square 12 point security bit like this:
16mm Triple Square XZN Socket for VW/Audi Porsche : Amazon.com : Automotive
If you have that, the only thing to watch for is when refilling, don't refill until it comes out of the fill hole, like every other car in existence. You need to use a "dipstick" to ensure the level is about 11mm below the fill hole. I used a small hex key, but you can use a paperclip or anything that will fit in the hole and show the level.
here is a good write up:
Pelican Technical Article: Boxster Differential / Manual Boxster Transmission Fluid Change - 986 / 987
Lastly, I can't recommend anything other than the Porsche fluid. I exclusively track my car and have used Redline, Swepco, Royal Purple and have had difficulty with them all. The Porsche fluid is expensive, but seems to work far better than any aftermarket.
gavinyuill is offline   Reply With Quote
Old 08-29-2013, 11:09 PM   #4
More's Avatar
Thanks mate
Old 08-30-2013, 04:36 AM   #5
thanks for the diy,
thanks god, i have a 6 speed trans, no need to order the special tool
another project before putting my racecar on track in 2 weeks
Old 08-30-2013, 08:05 AM   #6
As you fill the tranny with new fluid, with the car in gear, rotate a wheel so the oil distributes well, otherwise, you risk under filling the tranny.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 09-14-2013, 12:18 AM   #7
More's Avatar
Can you jack the car up with the one that comes with the car?
And do I need two or four jack stands??
Thanks.
Old 09-14-2013, 04:54 AM   #8
finally, this is an easy job,
done it 2 times last week
i did remove the cover under the tranny to help me reach the drain plug,
ive decided not to put it back since its a race car
Old 09-14-2013, 06:15 PM   #9
woodsman's Avatar
Thanks.
You didn't read the Pelican DIY's.
Old 09-14-2013, 06:19 PM   #10
woodsman's Avatar
Mosport???
Old 09-14-2013, 07:20 PM   #11
I punched a hole in my cover to make draining easier. Keep in mind there trans cooling ducts mounted on the cover. Don't think I would want to lose mine unless I had an external cooler.
spendy is offline   Reply With Quote
Old 09-15-2013, 01:12 PM   #12
Originally Posted by woodsman View Post
Mosport???
yup 3 days at mosport, then 2 days a tremblant, 5 days in a row, hope the car will be fine
i forgot those little ducts, ****************, I might put back the cover lol ,,,
Old 09-16-2013, 01:17 PM   #13
woodsman's Avatar
That cover would help prevent the suspension mounting points from spreading apart too- know?
Old 09-16-2013, 04:48 PM   #14
no, the diagonales do this, its pretty much only a cover that received the dust and dirt
and its in the way when you want to do a trans flush...
i dont know how effective are these little trans duct..
Old 09-17-2013, 05:48 PM   #15
woodsman's Avatar
wish I could join you... watch the wheelspin up the back straight at Mosport!
Old 11-28-2013, 09:48 PM   #16
More's Avatar
What a lousy site amazon is they don't ship out to Australia.
