		|  07-18-2012, 09:40 PM | #1 |
	| 2006 987
				Pay for wired fm modulator installed?
			This.
I think i would rather just pay about $100 and have someone install it.  They're only about $20-30 so $100 should cover everything, and then I have what I really want which is a headphone jack to my cdr210.  Sound quality will be good enough, I am in a convertible with 2.5 singing behind me anyway
I read the $200+ chinese 7" touchscreen thread but then it's another $150 for a decent install kit bezel and wires and mess and potential problems for a lot of what i don't need.  Don't need gps, phone does that.  I'll never use cd.  Cdr210 does radio.  iPod or phone does mp3.  Phone can even do HD radio or streaming radio and video.  And with cdr210 I don't have to worry about someone cutting the top to steal the stereo.  If cdr210 didn't work I would consider chinese touchscreen though but so far so good.  Cdr210 does not have cd changer controls otherwise I'd hook a headphone jack to that, and the boxster stereo that does offer that is $200+ used
Does this make sense or am I missing something?
Anyone else pay for a wired fm modulator install?
		|  07-18-2012, 10:03 PM | #2 |
	| Custom User Title Here
			Wired...as in wired into the cars power? I've never looked into one. My Sony hu has auxiliary input that I use for my ipod.
You could buy one of those that plug into the cigarette lighter(already setup for 12v), hard wire it into power, and hide it under the bottom tray(lots of room under there...that's where my digital tv converter is going). Then just route the headphone jack to a good location. I'd just drill a small hole into the the top of the tray/compartment and route it into there. That way you could plug in your ipod or phone and just set it in the tray...everything well hidden.
I'm still on the fence about the DD Chinese unit as well. Great unit and price, but that bezel and cage are beyond outrageously priced.
That, and the whole theft issue. I'd be more worried about my top being cut or window broken than I would be about the stereo being stolen.
				__________________https://youtube.com/@UnwindTimeVintageWatchMuseum
		|  07-19-2012, 05:13 AM | #4 |
	| 2006 987
					Originally Posted by 2003S   |
I have a cdr210
		|  07-19-2012, 05:22 AM | #5 |
	| 2006 987
					Originally Posted by particlewave  Wired...as in wired into the cars power? I've never looked into one. My Sony hu has auxiliary input that I use for my ipod.
That, and the whole theft issue. I'd be more worried about my top being cut or window broken than I would be about the stereo being stolen. |
There's two types of fm modulators:  wireless and wired
Wireless is probably the one you're familiar with.  They sell them at walmart and it's a weak fm transmitter that you tune in on your radio.  Problem is they sound horrible because FCC won't allow them to be powerful
Wired plugs in through your fm antenna.  Usually you unplug the antenna from the back of the stereo, plug this in, and then plug the antenna wire back to the wired fm modulator so you still get radio.  This sounds as good as regular radio since its going thru the same cable the radio goes thru
		|  07-19-2012, 06:47 AM | #6 |
			I see...yeah, I haven't looked into the FM modulators since the "cd revolution" of the '90's.
		|  07-19-2012, 08:16 AM | #7 |
	| Registered User
			Why not try the iP-BKRCD? It is wired, simple to install, and it will charge your phone as well. I used the one for the CDR-220 and couldn't be happier. Took all of 20 minutes if even that to install. As mentioned by particleweave, route the wire through the shelf and you have a nice clean install.
Here's the link:
http://www.discountcarstereo.com/iP-BKRCD.html
				________________________________________________________________
 2001 Boxster S Lapis Blue
 iPad Mini Dash Install
 DEPO Tail Lights
		|  07-19-2012, 09:38 AM | #8 |
	| 2006 987
					Originally Posted by BruceH   |
I do not have a cd changer
		|  07-19-2012, 09:52 AM | #9 |
	| Registered User
					Originally Posted by 986_inquiry  I do not have a cd changer |
Well that stinks! I wonder why the CD Changer has to remain? I think I would almost go for a new head unit then. They can be had with bluetooth for under $200. Crutchfield includes everything you need. Something like these:
Kenwood Excelon KDC-X696 CD receiver at Crutchfield.com
Alpine CDE-135BT CD receiver at Crutchfield.com
Or find a cheap used CDR-220. I am sure there are some out there then you could use the cable.
 DEPO Tail Lights
		|  07-19-2012, 09:52 AM | #10 |
	| 2006 987
					Originally Posted by particlewave  I see...yeah, I haven't looked into the FM modulators since the "cd revolution" of the '90's.    |
Same.  If the cdr210 would play burnt CDs I'd be fine, but every brand ive tried it struggles to read, even when burnt at 1x
		|  07-19-2012, 09:56 AM | #11 |
	| 2006 987
It's a Porsche, I can't put some cheap looking headunit in there.  Either factory or good looking large touchscreen
The used cdr220s I've found have all been $200+.  If they were cheaper, say $100, I would probably go that route
		|  07-19-2012, 10:03 AM | #12 |
	| Registered User
			Yes, I understand. That's why I kept the 220.
 DEPO Tail Lights
		|  07-19-2012, 10:06 AM | #13 |
	| Registered User
			Here's someone on the forum selling the CR-220 for $100http://986forum.com/forums/boxster-parts-sale-wanted/34762-2001-cr-220-price-reduced-$100.html
 DEPO Tail Lights
		|  07-19-2012, 11:39 AM | #14 |
	| Registered User
					Originally Posted by 986_inquiry  Same.  If the cdr210 would play burnt CDs I'd be fine, but every brand ive tried it struggles to read, even when burnt at 1x |
Did you finalize & close the disk? Older players have problems with CDs if you haven't properly closed the session.
				__________________Some kind of happiness is measured out in miles
 2003 Midnight Blue S
 LN IMS Retrofit
		|  07-19-2012, 12:57 PM | #15 |
	| 2006 987
					Originally Posted by 2003S  Did you finalize & close the disk? Older players have problems with CDs if you haven't properly closed the session. |
Yes
I've been burning CDs for a very long time.  My first was a 2x8x I bought for $220 in 1997
I am very familiar with how to burn CDs
		|  07-19-2012, 01:19 PM | #16 |
	| 2006 987
					Originally Posted by BruceH  Here's someone on the forum selling the CR-220 for $100http://986forum.com/forums/boxster-parts-sale-wanted/34762-2001-cr-220-price-reduced-$100.html
I'll contact them
So I can just take out my cdr210 and put in a cdr220?
		|  07-19-2012, 02:02 PM | #17 |
	| Registered User
I would assume so. The wiring harness should be the same, and if not, it shouldn't take too much to mod it.
 DEPO Tail Lights
		|  07-21-2012, 10:35 AM | #18 |
	| Registered User
 DEPO Tail Lights
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -8. The time now is 09:37 PM.
