Old 07-18-2012, 10:40 PM   #1
2006 987
986_inquiry's Avatar
Pay for wired fm modulator installed?
This.
I think i would rather just pay about $100 and have someone install it. They're only about $20-30 so $100 should cover everything, and then I have what I really want which is a headphone jack to my cdr210. Sound quality will be good enough, I am in a convertible with 2.5 singing behind me anyway
I read the $200+ chinese 7" touchscreen thread but then it's another $150 for a decent install kit bezel and wires and mess and potential problems for a lot of what i don't need. Don't need gps, phone does that. I'll never use cd. Cdr210 does radio. iPod or phone does mp3. Phone can even do HD radio or streaming radio and video. And with cdr210 I don't have to worry about someone cutting the top to steal the stereo. If cdr210 didn't work I would consider chinese touchscreen though but so far so good. Cdr210 does not have cd changer controls otherwise I'd hook a headphone jack to that, and the boxster stereo that does offer that is $200+ used
Does this make sense or am I missing something?
Anyone else pay for a wired fm modulator install?
986_inquiry is offline   Reply With Quote
Old 07-18-2012, 11:03 PM   #2
Wired...as in wired into the cars power? I've never looked into one. My Sony hu has auxiliary input that I use for my ipod.
You could buy one of those that plug into the cigarette lighter(already setup for 12v), hard wire it into power, and hide it under the bottom tray(lots of room under there...that's where my digital tv converter is going). Then just route the headphone jack to a good location. I'd just drill a small hole into the the top of the tray/compartment and route it into there. That way you could plug in your ipod or phone and just set it in the tray...everything well hidden.
I'm still on the fence about the DD Chinese unit as well. Great unit and price, but that bezel and cage are beyond outrageously priced.
That, and the whole theft issue. I'd be more worried about my top being cut or window broken than I would be about the stereo being stolen.
Old 07-19-2012, 06:22 AM   #3
2006 987
There's two types of fm modulators: wireless and wired
Wireless is probably the one you're familiar with. They sell them at walmart and it's a weak fm transmitter that you tune in on your radio. Problem is they sound horrible because FCC won't allow them to be powerful
Wired plugs in through your fm antenna. Usually you unplug the antenna from the back of the stereo, plug this in, and then plug the antenna wire back to the wired fm modulator so you still get radio. This sounds as good as regular radio since its going thru the same cable the radio goes thru
Old 07-19-2012, 02:30 AM   #4
2003S's Avatar
I didn't pay it, but was about $50 for parts (modulator and antenna adapters) for the CDR-23. If you have the 220, I believe you can go right in without the antenna adapter-I'd have gone that route if I could have.
http://986forum.com/forums/general-discussions/35744-cdr-23-aux-input-achieved.html
For CDR-220 iPod only:
iP-BKR2 iPod Adapter for Becker Radios with "AUX" Menu option :: iPod Adapters & Interfaces :: Discount Car Stereo
CDR-220 generic aux in: http://www.swstereo.com/accessdetail.php?prodID=96
2003 Midnight Blue S
LN IMS Retrofit
Old 07-19-2012, 06:13 AM   #5
2006 987
CDR-220 generic aux in: iPod Adapter - SW Stereo Specialists
I have a cdr210
Old 07-19-2012, 07:47 AM   #6
I see...yeah, I haven't looked into the FM modulators since the "cd revolution" of the '90's.
Old 07-19-2012, 10:52 AM   #7
2006 987
Same. If the cdr210 would play burnt CDs I'd be fine, but every brand ive tried it struggles to read, even when burnt at 1x
Old 07-19-2012, 12:39 PM   #8
2003S's Avatar
Did you finalize & close the disk? Older players have problems with CDs if you haven't properly closed the session.
LN IMS Retrofit
Old 07-19-2012, 01:57 PM   #9
2006 987
Yes
I've been burning CDs for a very long time. My first was a 2x8x I bought for $220 in 1997
I am very familiar with how to burn CDs
Old 07-19-2012, 09:16 AM   #10
BruceH's Avatar
Why not try the iP-BKRCD? It is wired, simple to install, and it will charge your phone as well. I used the one for the CDR-220 and couldn't be happier. Took all of 20 minutes if even that to install. As mentioned by particleweave, route the wire through the shelf and you have a nice clean install.
Here's the link:
http://www.discountcarstereo.com/iP-BKRCD.html
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 07-19-2012, 10:38 AM   #11
2006 987
Here's the link:
iP-BKRCD iPod Adapter for Select Becker Radios with CD Changer :: iPod Adapters & Interfaces :: Discount Car Stereo
I do not have a cd changer
Old 07-19-2012, 10:52 AM   #12
BruceH's Avatar
Well that stinks! I wonder why the CD Changer has to remain? I think I would almost go for a new head unit then. They can be had with bluetooth for under $200. Crutchfield includes everything you need. Something like these:
Kenwood Excelon KDC-X696 CD receiver at Crutchfield.com
Alpine CDE-135BT CD receiver at Crutchfield.com
Or find a cheap used CDR-220. I am sure there are some out there then you could use the cable.
DEPO Tail Lights
Old 07-19-2012, 10:56 AM   #13
2006 987
It's a Porsche, I can't put some cheap looking headunit in there. Either factory or good looking large touchscreen
The used cdr220s I've found have all been $200+. If they were cheaper, say $100, I would probably go that route
Old 07-19-2012, 11:03 AM   #14
BruceH's Avatar
Yes, I understand. That's why I kept the 220.
DEPO Tail Lights
Old 07-19-2012, 11:06 AM   #15
BruceH's Avatar
Here's someone on the forum selling the CR-220 for $100
http://986forum.com/forums/boxster-parts-sale-wanted/34762-2001-cr-220-price-reduced-$100.html
DEPO Tail Lights
Old 07-19-2012, 02:19 PM   #16
2006 987
I'll contact them
So I can just take out my cdr210 and put in a cdr220?
Old 07-19-2012, 03:02 PM   #17
BruceH's Avatar
I'll contact them
I would assume so. The wiring harness should be the same, and if not, it shouldn't take too much to mod it.
DEPO Tail Lights
Old 07-21-2012, 11:35 AM   #18
BruceH's Avatar
Here's a CR220 on eBay that might work for you.
PORSCHE BOXSTER 986 911 996 CR-220 OEM FACTORY AM FM CASSETTE RADIO 4362 BECKER | eBay
DEPO Tail Lights
