Old 06-29-2012, 04:37 PM   #1
Lightbulb Manual climate control Double Din install help
Does anyone know if it's possible to replace the manual heater controls with the automatic climate control. the manual heater controls on the 1997 model boxster are 7cm in height, larger than a standard din of 6cm. The easy answer is to replace with the auto climate control but i'm not sure if it can be done, otherwise it looks like i will have trim 5mm of the top and bottom of the current fascia.
I am determined to install a double din AVIC unit.
D3LUXE is offline   Reply With Quote
