Old 03-24-2011, 12:14 PM   #1
Angry Coolant tank
:ah: All I can say is I hate this hose crap!!! 600 to install and I cant get the last two hoses loose!!!!
98 Boxster
92 Benz sportline 2.6
J's boxster is offline   Reply With Quote
Old 03-29-2011, 08:31 AM   #2
Coolant tank hoses
To get the hoses loose from the engine compartment, you need to pull on them a little, and then slide the clamp upward so you can see it. I did my tank from the trunk. It wasn't easy and I had a friend help (you defenetly need someone to help). It took us 2 hours flat to get the new tank in there. So far it's worked great.
JC
Tech-Art 986 Boxster
JC-986 is offline   Reply With Quote
Old 03-29-2011, 02:04 PM   #3
You can get some additional access, which will allow you at least to see what you are doing a little better, by pushing in the large rubber plug which encases the wire bundle from the DME. Once you push the plug forward, only the circumference of the wire bundle will be in the way, but you can get your hand in there or see what's going on through the large hole.
Regards, Maurice.
schoir is offline   Reply With Quote
Old 03-31-2011, 12:21 PM   #4
Cool I tried!
Well, after bloody knuckles and a broken plastic nipple along with the oil filler tube... The car goes to the mech in a week. I got the tank out but it has just turned into too much. Oh well. At least they are going to do it for around 300 with peace of mind and a flush and refill with the Porsche coolant. Too bad someone hasn't used ( that I k ow of) metal braided lines for the oil filler and other coolant hoses.
98 Boxster
Old 04-27-2011, 04:28 PM   #5
Update
It was 1100 bucks!!!! Cant believe it was that much!!!
98 Boxster
Old 04-27-2011, 11:55 PM   #6
Just getting ready to tackle this myself.. Your experience sounds like a horrible one and is quite worrying to me
tawheed is offline   Reply With Quote
