Thread: Coolant tank
Old 03-29-2011, 02:04 PM   #3
schoir
Originally Posted by J's boxster
:ah: All I can say is I hate this hose crap!!! 600 to install and I cant get the last two hoses loose!!!!
You can get some additional access, which will allow you at least to see what you are doing a little better, by pushing in the large rubber plug which encases the wire bundle from the DME. Once you push the plug forward, only the circumference of the wire bundle will be in the way, but you can get your hand in there or see what's going on through the large hole.
Regards, Maurice.
schoir is offline   Reply With Quote
