Old 02-14-2017, 04:00 PM   #81
Originally Posted by Lew View Post
There is supposed to be a hack that will let one use the low beams as DRL's....
As easily as the inner lenses burn and melt, this would be a bad idea.
Old 02-23-2017, 08:33 PM   #82
So guys, thanks for the info in the thread. Got my LED's and taps from Amazon today and did the hack. Super easy and it looks great!
Only question I have....does anyone else's fog light indicator light on the headlight switch stay on the whole time? is there a way to have it turn off, or it just stays on now?
That boy's got the Devil in him.
Justin327 is offline   Reply With Quote
Old 03-07-2017, 08:23 PM   #83
itskenallen's Avatar
What kind of fuse taps are needed for this guys.. Standard size?
For the guys with Leds in place of the H7 fogs, what wattage bulbs are you using?
Also worth mentioning that LED H7 bulbs are a nice modern upgrade over standard dim/high beam headlights too. No ballast and extra wiring needed either unlike HID kits.
Sent from my SM-G928F using Tapatalk
itskenallen is offline   Reply With Quote
Old 03-07-2017, 08:33 PM   #84
JayG's Avatar
I was concerned about the fans on the LED H7's with our headlight assembly, they would be enclosed with no air flow
The fuse taps are standard size. NAPA auto parts has them
Old 03-07-2017, 08:38 PM   #85
I'm in Ireland mate so Napa parts means nothing to me.. Lol. Thanks anyway.
Some have heatsinks and no fans.
However, U could always drill a hole in the assembly.. Kinda like what you'd have to do with a HID kit
Old 03-07-2017, 09:34 PM   #86
Lew
So Blessed!
Lew's Avatar
$1.99 at Autozone
Best Fuse and Accessories Parts for Cars, Trucks & SUVs
Lew is offline   Reply With Quote
Old 03-13-2017, 02:31 PM   #87
If one was to use LED H7's for the fogs in this hack, what wattage is recommended? Everything from 50W to 150W is available in the H7 range. I know the halogens are 50W but not sure if the leds would equate to same wattage.
Also I was thinking of replacing my Halogen dims with Led versions. Would 50W be recommended here also? I'm kind of confused as to why 80 & 150W are available so easily.
Old 03-13-2017, 04:10 PM   #88
Fintro11's Avatar
Becareful with what led's you use, even with led's it started burning the lens on my car
Old 03-14-2017, 07:00 AM   #89
I'm using these, 60w, only SLIGHTLY bluish. makes a nice contrast with the Litronics.
https://www.amazon.com/gp/product/B01HO8TK4W/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Old 03-14-2017, 07:22 AM   #90
Very nice.. All H7 leds are 6000k ish afaik. Ideal colour imo.
Btw..any pics in daylight?
Old 03-14-2017, 12:29 PM   #91
Uk
Hi guys, Has anyone done this hack in the UK, Europe or Australia? Reason I ask is, I just cannot get it to work, I know the fuse and relay location differ from the US.
The relay is in position 24 and the fuse is in position A7 on a UK car.
Any ideas PLEASE...
Regards Carl
kallie is offline   Reply With Quote
Old 03-14-2017, 12:58 PM   #92
Any ideas PLEASE...
Regards Carl
Thinking about doing it myself very shortly but dont have fusetaps at hand.
if i had i could try it out tomor. Im in Ireland btw
Old 03-14-2017, 01:00 PM   #93
Originally Posted by savinor View Post
I wanted DRL but did not want to use the low beams (Litronics) on my 2000S. My approach is to use the front Fog Lights as the DRL using LED bulbs which I purchased at auction. Of course the OE H7 bulbs can also be used.
The hack involves a single jumper wire between the Fog light relay and the Fog light fuse. Now the Fog lights go on and off with the ignition switch and are switched off when the high beam headlights go on.
Required Materials:
(10) inches of 16 gauge insulated wire
(2) Fuse taps, Radio Shack P/N 270-1204
(2) female Quick Disconnectors, Radio Shack P/N 64-3131
Procedure:
1. Strip the wire ends and crimp on the Quick Disconnects.
2. Plug in a fuse tap to each of the Quick Disconnects.
3. Locate the Fog light relay in the panel above the Fuse panel. It is #12, the far left relay in the second row from the bottom.
4. Attach one of the fuse taps to pin 86 of the relay. Bend the tap to conform to the bottom of the relay. Use a piece of electrical tape to hold the wire to the side of the relay.
5. Return the relay to position #12 and run the other end of the wire to the top of the fuse panel.
6. Remove the Fog light fuse, 25 Amp, #7 (top row, 4th position from the right) from the fuse panel. Slip the fuse tap on the wire end to the upper leg of the fuse.
7. Return the fuse with the tap up into position #7.
You're done.
Anyone got any pics of the fuse tap attached to the relay?
Might have to improvise here as im having trouble locating some fuse taps
Old 03-14-2017, 01:56 PM   #94
I made a diy fuse tap
Old 03-14-2017, 01:59 PM   #95
Old 03-14-2017, 02:08 PM   #96
This is just and old relay but hopefully you'll get the idea
Old 03-14-2017, 02:19 PM   #97
That's perfect Carl thx. Ur just connecting that pin to the fuse so. That's no biggie. Can u point me to where the relay and fuse are located and I'll give it a whirl tomoro?
Old 03-15-2017, 08:18 AM   #98
Thanks, no daylight pics yet, I'll snap some if the sun's still up when I get home.
Old 03-15-2017, 11:53 AM   #99
Fuse is top row number 7
Relay is in location 24
Old 03-15-2017, 01:26 PM   #100
It was raining here today so I couldn't go at mine. Are u sure its relay 24? What pin did u tap to?
Is there any relay in position 12? (I know it says USA/Japan) but worth a try.
